Capacitor charge in parallel RC circuit
4 replies · 3K views
woaname
What is Q(∞), the charge on the capacitor after the switch has been closed for a very long time?
a circuit, whose image is attached, has known values for the resistors : R1 = R2 = 72 Ω, R3 = 101 Ω and R4 = 79 Ω, is C = 56 μF, V = 24 V.
kirchoff's laws
here is what I've calculated from preceding questions:
1) I1(0) just after the switch is closed?-------> 0.158940397 A
2) I1(∞)------------------------------------> 0.074074074 A
ive tried making the circuit at t=infinity, where the capacitor will have no current. so basically it won't interfere, but i can't see how the circuit changes?
I agree with the answers you got for the previous parts. I don't understand what you mean when you say that you don't know how the circuit changes... As you said, the current through the capacitor becomes zero at t=infinity. And I'm guessing you used this fact to get the answers to the previous questions. So it looks like you do know how the circuit changes as t=infinity.
The problem you are trying to work out now is what is the charge on the capacitor at t=infinity. Well you have worked out the current through the resistors at t=infinity, so think of a way to work out the voltage across the capacitor at t=infinity. Nothing is special at t=infinity, it is just handy in this problem because the current at t=infinity is fairly easy to calculate, as you have done. So don't be afraid to use the usual rules for circuit behaviour even though t is tending to infinity.
At T->∞ the capacitor might as well not be in the circuit (because Ic=0). So take it out and work out the voltage just due to the resistors.
Then apply the well known equation that relates the charge on a capacitor to it's voltage.
yes BruceW, it just took a little doodling and experimenting, but i figured out the question. thanks for your input :D, and CWatters, thanks to you too
no problem :) glad to help.
