Capacitor charging with unknown resistor
To determine the resistance in a capacitor charging circuit, the relationship between charge, voltage, and resistance can be utilized. The equation q=Cv can be rearranged to express resistance as R=-t/(C ln(Cv/Q)). Additionally, differentiating the voltage equation with respect to time allows for the measurement of current at various points, which can also lead to resistance calculation. The discussion references the potential use of methods like the Anderson Bridge for resistance measurement. Understanding these principles is crucial for solving the problem effectively.
cdotter
Capacitor voltage as a function of time is recorded for a simple direct current RC series charging capacitor. How could we determine the resistance of the resistor?
q=Qe^\frac{-t}{RC}
I understand the question I'm just having trouble figuring it out.
If I know the voltage at a certain time t, couldn't I say that q=Cv? Then
Cv=Qe^\frac{-t}{RC} \Rightarrow R=\frac{-t}{C\;ln(\frac{Cv}{Q})}
Where Q=CV and V=the voltage of the capacitor after it's finished charging?
Or is q=Cv incorrect?
Anyone?
That would work. Another way is to differentiate the equation wrt time to get current and to measure current at different points in time. From those values too you can find the resistance. I think this principle is used in measurement of resistances using the Anderson (?) Bridge. I might be thinking of another bridge though.
I didn't think of that. Thank you.
