Capacitors connected in series?
  • Level: Undergrad
  • Thread starter Thread starter mohamed el teir
    Capacitors Series
34 replies · 5K views
re post #23 (Bottom left corner of the diagram)
The bottom capacitor goes from +Q, -Q to 0Q, +2Q. So the voltage polarity has reversed. That certainly looks like it's been discharged and recharged in the opposite direction :-)
A change from -Q to +2Q implies a current of 3Q flowed. Yet other nodes change from +Q to +2Q which is only an increase of Q. How is that possible if they are in series?
rumborak said:
Sorry, had not noticed the reversal of charges in case 3. But still, case 1 you can't really calculate like that. The formulas you are using presume ideal components; at the moment of your case 1 picture, you are short-circuiting ideal components. Meaning you have infinite current, and an unaccounted-for potential difference between the capacitors.
mmm, but i think all that in the paper doesn't hold unless c1 = c2, the final answers wouldn't change but the steps would change, for example in case 2 if c1 not equal c2 therefore Q1 will not be equal to Q2 but there summation still will be 2Q
@CWatters, crap, you are correct, the picture is incorrect. The two right plates should read -2Q (top) and 0Q (bottom). Which would mean, when you cross them over, you are connecting a 2Q to -2Q. The reversal of polarity is what kills it in the end.
It was a nice idea, lol.
EDIT: Thinking about it more, there's also the argument that charges are a zero-sum game. If I create a 2Q somewhere, somewhere else must be -2Q. The only way of reconnecting it without massive discharge would be to find another 2Q potential. Which really could only come from another device.
Hmmmmm, got to think more about this.
so i think case one would only be short circuit when c1=c2 :D , but if c1 not equal c2 so voltage will be distributed not equally between them (because in series) so i think it will not be shorted
Throw a few diodes into the mix and you can make a high voltage charge pump..
http://en.wikipedia.org/wiki/Cockcroft–Walton_generator
