Cardinality of the set of ordinal numbers
AlephOmega
Does anyone happen to know what the cardinality of the set of ordinal number (transfinite and otherwise) is? A simplified proof would also be much appreciated. Recently I have been very interested in transfinite numbers and the logically gorgeous proofs involved :D
The ordinal numbers do not form a set. There are too much ordinal numbers in order for it to be a set. Instead, the ordinal numbers form a "proper class".
Thus, since the ordinal numbers do not form a set, they do not have a cardinality. Likewise, the cardinal numbers do not form a set and thus don't have a well-defined cardinality.
Can't you make a set out of anything? I already know the ordinals are uncountably infinate, so I just want it one step farther, "how" uncountably infinate.
PS. I mean the set of the numbers themselves, not the sets they describe.
No, you can't make a set out of anything! That's the biggest difference between "naive set theory" and "axiomatic set theory". In axiomatic set theory, there are strict limitations on what can be a set and what can't be a set. It turns out that the ordinals do not form a set.
I don't know how much you know about ordinals, but here's an easy argument why the ordinals cannot be a set:
Assume that there exists a set A consisting of all the ordinals. Then \bigcup{A} is an ordinal \alpha. But then \alpha+1 is an ordinal which is not contained in A.
The above proof is known as the Burali-Forti paradox. It was one of the reasons that axiomatic set theory was developed.
Oh. Fun stuff.
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
Thread 'Detail of Diagonalization Lemma'
The following is more or less taken from page 6 of C. Smorynski's "Self-Reference and Modal Logic". (Springer, 1985) (I couldn't get raised brackets to indicate codification (Gödel numbering), so I use a box. The overline is assigning a name. The detail I would like clarification on is in the second step in the last line, where we have an m-overlined, and we substitute the expression for m. Are we saying that the name of a coded term is the same as the coded term? Thanks in advance.
