Carnot engine rejected heat problem
The discussion centers on solving a problem involving two Carnot engines, A and B, where Engine A takes in 5550J of heat and delivers 1750J of work while rejecting heat to a cold reservoir at 503K. The rejected heat from Engine A serves as the input for Engine B, which also delivers 1750J of work. The key equations used are e=1-Tc/Th and e=W/Qh, leading to the determination of temperatures T1 and T2, with T1 calculated as 734.3K. The conservation of energy principle is crucial for finding the input heat for Engine B.
  • Understanding of Carnot engine principles
  • Familiarity with thermodynamic equations, specifically e=1-Tc/Th and e=W/Qh
  • Knowledge of heat transfer and energy conservation
  • Basic algebra for solving equations
  • Study the principles of Carnot engines and their efficiency calculations
  • Learn about the conservation of energy in thermodynamic systems
  • Explore advanced thermodynamic equations and their applications
  • Investigate real-world applications of Carnot engines in energy systems
Students studying thermodynamics, engineers working on energy systems, and anyone interested in the principles of heat engines and energy conservation.
Nimbalo
From the hot reservoir at a temperature of T1, Carnot Engine A takes an input heat of 5550J, delivers 1750J of work and rejects heat to a cold reservoir that has a temperature of 503K. This cold reservoir also serves as the hot reservoir for a second Carnot Engine, B, which uses the rejected heat from the first engine as input heat. Engine B also delivers 1750J of work, while rejecting heat to an even colder reservoir that has a temperature T2. Find T1 and T2.
e=1-Tc/Th
e=W/Qh
I plugged in my values into the e=1-Tc/Th and e=W/Qh equations to solve for the Th, or T1. As an answer, I got 734.3K. However, I'm missing a variable for my second Carnot engine. What is the input heat for engine B? I tried doing 734.3-503K, but that gives me answers in K and makes the equation not work. I don't know what I'm supposed to use for the input heat.
Welcome to PF :smile:
It's the same as the output heat from engine A:
... a second Carnot Engine, B, which uses the rejected heat from the first engine as input heat.
Engine A has 5550 J of input heat. Of that 5550 J energy, 1750 J is used to do work. The remaining energy has to go somewhere (conservation of energy) ...
so what does this mean? what do i do with the conservation of energy?
Equate the input energy with the total output energy.
Qin = W + Qout
If you need more help with the problem, you will have to show how far you have gotten and the work you have done.
