Carnot engine working in reverse poblem-
The problem involves a heat pump used to heat a building, with an outside temperature of -5.0 Celsius and an inside temperature of 22 Celsius. The coefficient of performance (COP) is given as 3.8, and the heat pump delivers 7.54 MJ of heat to the building each hour. The question seeks to determine the rate of work required to operate the heat pump, which is described as a Carnot engine working in reverse.
  • Participants discuss the definition of the coefficient of performance (COP) and its relation to the heat pump's operation. Some express confusion about the correct equations to use and question the clarity of the problem statement. Others attempt to relate the COP to the temperatures involved and the work required.
There is ongoing exploration of the relationships between the heat delivered, the work done, and the COP. Some participants have provided guidance on using the COP in calculations, while others are questioning the assumptions made regarding the Carnot efficiency and the given COP value. Multiple interpretations of the problem are being discussed without a clear consensus.
Participants note the potential confusion arising from the problem's wording, particularly regarding the COP values and their implications for the calculations. There is also mention of the need for clarity on whether the heat pump operates as a Carnot engine or under different conditions.
LandOfStandar
A heat pump is used to heat a building. The outside temp is -5.0 Celsius and the temp inside the building is to be maintained at 22 Celsius. The pump's coefficient of performance is 3.8, and the heat pump delivers 7.54MJ as heat to the building each hour. If the heat pump is Carnot engine working in reverse, at what rate must work be done to run it?
Kc = QL /(QH - QL) = TL/(TH-TH)
I am lost, help, Am I using the right equation, what do I do first.
I have tried this many times and I just need help understanding what I am looking for and how to start to get it.
Your definition of Kc (COP) is incorrect. What is the definition of COP for a heat pump in terms of heat out, work in?
For a Carnot cycle, how is that efficiency related to temperature?
AM
k =Qin/W = Qin/(Qin - Qout) = Tin/(Tin - Tout)
the other one was from my text
anyone
So how is the overall COP related to the COPs of each part?
[tex]\kappa_{total} = Q_{total}/W_{total} = (Q_{h1} + Q_{h2})/(W_1 + W_2)[/tex]
Now we know W1:
[tex]W_1 = Q_{h1}/\kappa_1[/tex]
We also know W2:
[tex]W_2 = Q_{h2}/\kappa_2[/tex]
We know [itex]\kappa_1[/itex] and [itex]\kappa_2[/itex]: eg:
[tex]\kappa_1 = T_1/(T_1-T_2)[/tex]Work out the expression [itex]\kappa_{total}[/itex] in terms of these known variables.
AM
I did not have those formulas
I wish I could find these in my textbook Fundamentals of Physics by Halliday and Resnick
ok, thank you
[tex] \kappa_1[/tex] is that the pump's coefficient of performance
with one being the given 3.8 and finding the other as 9.926
are one of the Q 7.54x10^6J what is the other, or is that Q total?
k total = 3.8 + 9.9 = 13.7
Q total = 7.54x10^6J
what am I trying to get?
W net / 3600sec (one hour) to get Watts or power
Please someone help I need to understand this the exam is coming up and I need an understand of this
I confused you on my last answer. I was thinking of the other problem you had posted on the efficiency of two Carnot engines. Sorry about that. Just ignore my last answer.
You are trying to get the amount of work done (per unit time).
You have correctly stated the relationship between COP and temperature:
COP = Qh/W = Th/(Th-Tc)
You are given Qh (actually dQh/dt) = 7.54MJ (per hour)
You are given Th and Tc. You just need to determine W (per hour).
AM
what is the coefficient of performance is 3.8
The question is not clear. If it is a Carnot heat pump, the COP is:
[tex]COP = Q_h/W = Q_h/(Q_h - Q_c) = T_h/(T_h - T_c)[/tex]
For these temperatures, the COP is 10.9
However, the question says that the COP is 3.8. So it is not a Carnot heat pump. Work out the rate of work for both COPs and tell your prof that the question is not clear which one you are supposed to use.
AM
the answer is 440Watt and I can not get it either way
440 watts is not correct. 440 watts = 440 x 3600 = 1,584,000 Joules/hour. At a COP of 3.8, this means it is pumping 6,019,000 Joules of heat per hour. At a COP of 10.9 (295/27), it would pump 30.1 MJ per hour.
AM
10K
