Can a Casimir Engine Defy Inertia in a Spinning Centrifuge?
Lord Flasheart
A theoretical question on a known effect:
Suppose one were to make a Casimir-engine for the production of negative energy. If one placed said engine in a spinning centrifuge on the International Space Station, would the negative energy repel the centrifugal effect, and rise to the weightless center? (or as close to the center as it can get?)
Information will be most appreciated.
What is a casimir engine?
]home.xtra.co.nz/hosts/Wingmakers/Zero-PointEnergy.html [/URL] "A Casimir engine would be one whose cylinders could only fire once, after which the engine become useless. "
Generally, a Casimir-engine is a device for the production of exotic matter/negative energy, which can lower the inertial mass of an object, through the utilization of the Casimir Effect.
Now, should the negative energy seek the inertially weak center of a centrifuge, or should it cause some changes in the rotation speed? In a similar environment, say, an accelerating spacecraft , should the negative energy do the same?
Keep in mind, I am doing this for a science-fiction story, and would like to heighten my scientific accuracy.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
