Casimir Effect and Perpetual Motion
Zeteg
I read about the Casimir effect right away, and the first thing that came to me was a question. If quantum fluctuations can in empty space can move two completely uncharged metal plates at small distances, then wouldn't that give the potential for a perpetual motion machine?
I realize perpetual motion machines are against the laws of physics, but then again, classical physics often don't apply to quantum mechanics, so would this be a possibility?
I realize that the machine would be sustained off the fluctuations of space, but as long as space is there--as long as we exist--then it would theoretically run, would it not? For that purpose, would it not be perpetual? Perhaps I don't have a deep enough understanding of the Casimir effect?
If someone could explain that'd be great :)
When you separate the plates to do it again you will have to fight against the very same force. You would not gain any energy.
But could we not "hold" those plates at those positions, and the energy pulling them in would subsequently be the energy gained?
There is a force pulling them in not an energy. In order to do work(gain energy) you must let them move inwards.
But would I be correct to assume that this creates energy? If so, this still provides a basis for a perpetual motion machine?
No because eventually the plates would touch and you would not be able to let them move closer together. Hence no more energy gain. Then you would need new A)plates or B)separate the plate you have. A) is not economical, B) you don’t gain any net energy.
Also the work(energy) that you could gain from letting the two plates come together is very small.
My question isn't if it's practicle or not, but, is it possible?
Yes I know. I have never heard any evidence that this is possible. There is no free ride, when you get energy it comes from somewhere. Earlier Physicsforms discussions:
https://www.physicsforums.com/archive/t-4777_Free_energy_and_anti-gravity?.html
https://www.physicsforums.com/archive/t-39619_Zero-point_energy_-_a_question_for_you_all..html
https://www.physicsforums.com/archive/t-35190_Negative_energy_density_in_a_Casimir_vacuum.html
This topic has been discussed many times before. I think that is why you are only getting me to respond.
Ahh I see. Thank you :)
First, I would like you to look at the a quote from the very first message "...Casmir effect, be attracted to one another with 0.13 grams of force." Force is not calculated in grams; force is calculated in Newtons(N). Now, let's look at what work is. Work is force times distance moved. A 10N weight moved 5 meters would produce 50J(fifty joules) of work. A brick held away from your body produces no work. You would get tired, but in physics you are not working! Why? The brick is not being moved. All the brick is doing is creating a force. Force times zero distance equals zero work.
The Casimir effect produces a force between two plates just like gravity does with you and the ground. The means by which the force is produced is unimportant for this discussion. Now like a brick being dropped to the ground, a metal plate will be attracted to another metal plate and will fall to the stationary plate (it is odd thinking of an object falling upwards). Once the brick has released its energy on the ground, you must raise it again to get more energy, but in raising the block you undid all your work! Total energy gained is zero in zero friction. The Casimir effect is no different. Metal plate falls. Metal plate is picked up undoing all work gained.
Good example binarybob0001.
Let me make clear that I was not trying to point out the correctness in those threads only that this has been discussed many times before. Many threads have been started with mistaken beliefs about the Casmir effect. Hence why few people have responded to this thread.
Hi,
I have read (I forget where) that some practical and theoretical work done on the Casimir effect suggest that under some conditions the force can be negative.
These conditions are dependent on temperature, light, e/m fields and other variables.
juju
So the plates would push apart? Mind giving a reference if you can, it sounds like an interesting article.
Sorry if I'm being dense here, but how do we know that the force caused by the Casimir Effect is conservative in all directions? As I understand it, two parallel plates will be pulled together in a vacuum in the direction of their normal vectors. However, I have seen no argument for why "sliding" the plates apart in a direction perpendicular to their normals would cost energy.
The Casimir effect is a fluctuation induced force, predicted by statistical mechanics, which is consistent with classical thermodynamics, which claims that no perpetual motion machines are possible.
The `Friction' of Vacuum, and other Fluctuation-Induced Forces
Mehran Kardar, Ramin Golestanian
http://arxiv.org/abs/cond-mat/9711071
I'm blatently being dense too but I can't see why sliding the plates apart in a direction perpendicular to their normals would cost any energy either, if u could then arrange the plates in some sort of loop, could u not get them to move around perpetually? I know it won't work but i can't work out why.
Casimir force is an attractive force which depends on the distance.
Left call it a 'Casimir Gravitational field' :)
This field is a potential field
Hence, no tricks with loops would work.
(I know, it is an oversimplification)
