What Distance Makes the Casimir Effect Negligible?
_PJ_
I was thinking recently about the Casimir Effect and at what distance does the effect become negligible?
Is there any relevance on the surface area (or difference in areas) between the plates (I personally held the opposite, that any point can be considered to have equivalent pressure as any other approximated over time).
Naturally, this distance would entail the point at which there is a balance between the internal (i.e. between plates) and external pressures is when the plates are no longer 'pushed' together as result, but at what length does this occur? Presumably there will always be a very slight imbalance one way or the other due to continuous fluctuation, although at the given length there will be an overall equilibrium so as there is no net change in the plate positions over time.
ALMOST related, and perhaps worthy of its own thread, but it is relevant enough to be here I felt, is there any evidence or possibility for "capillary action" or suitable equivalent analogue with Casimir effect type small spaces and quantum foam 'fluidity'?
At what distance does the gravitational attraction of Earth become negligible? There is no sharp border, it just gets weaker and weaker.
For parallel plates of ideal conductivity, it is ##\displaystyle {F_c \over A} = -\frac {\hbar c \pi^2} {240 a^4}## with the distance a.
Likes bhobba
Negligible only has meaning with respect to some kind of comparison.
Likes vanhees71
Thank you so much!
As is usually the case with such questions, with hindsight it seems remarkably obvious!
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
