Causal Structure of Metric Prop.: Matrix Size Differs
12 replies · 2K views
smoking-frog
Proposition: Consider an ##n + 1##-dimensional metric with the following product structure:
$$ g=\underbrace{g_{rr}(t,r)\mathrm{d}r^2+2g_{rt}(t,r)\mathrm{d}t\mathrm{d}r+g_{tt}(t,r)\mathrm{d}t^2}_{:=^2g}+\underbrace{h_{AB}(t,r,x^A)\mathrm{d}x^A\mathrm{d}x^B}_{:=h} $$
where ##h## is a Riemannian metric in dimension ##n-1##. Then any causal vector for ##g## is also a causal vector for ##^2g##, and drawing light-cones for ##^2g## gives a good idea of the causal structure of ##(\mathcal{M},g)##.
I really don't understand this proposition. The metric tensor ##^2g## can be represented in a ##2\times 2## matrix, and ##g## corresponds to a ##(n+1) \times (n+1)## matrix. How can I then check ##\bigg(g(x^\mu, x^\nu)<0\bigg) \implies \bigg(\; ^2g(x^\mu, x^\nu)<0\bigg) ## for the same vector ##x=x^\mu \partial_\mu## if the dimension of the corresponding matrices is different?
Their dimensions are not different. ##^2g## and ##h## are metrics only on submanifolds of your space-time and it is here more relevant to consider them simply as tensors in ##n+1## dimensions. Obviously, neither ##^2g## nor ##h## are metric tensors on their own in the full space-time, but their sum ##g = {}^2g + h## is. However, ##h## is still positive semi-definite and so ##h(X,X) \geq 0## for any vector ##X## (you really should not use coordinates ##x^\mu## as arguments for your metric, the coordinates are not vectors). It follows that
g(X,X) = {}^2g(X,X) + h(X,X) \geq {}^2g(X,X).
Thus, if ##g(X,X) \leq 0##, then
^2g(X,X) \leq g(X,X) \leq 0.
Thanks!
Yeah, I forgot the basis vectors in the metric, that was a typo.
This was not my main issue. My main issue was that if ##x^\mu## are the coordinates, which is rather conventional, then ##x^\mu\partial_\mu## is not a vector field. You should therefore typically use some other notation for a general vector.
Why is ##x^\mu \partial_\mu## not a vector field?
Because it does not transform correctly under coordinate transformations.
If you just look at a particular coordinate system, it might define a vector field (at least on that coordinate patch), but that vector field will generally not take the form ##x'^{\mu'}\partial'_{\mu'}## in a different coordinate system.
Edit: Furthermore, it is not an arbitrary vector field, which is really what you want in this case.
Edit 2: To illustrate. Consider the position vector in 2D Euclidean space. It can be written ##\vec x = x^i \vec e_i## in Cartesian coordinates. However, it is not equal to ##r\vec e_r + \theta \vec e_\theta## in polar coordinates.
$$x'=x'^\nu \frac{\partial}{\partial x'^\nu}$$
Then
$$ \frac{\partial}{\partial x'^\nu}=\frac{\partial x^\mu}{\partial x'^\nu}\frac{\partial}{\partial x^\mu}\\
x'^\alpha=\frac{\partial x'^\alpha}{\partial x^\beta}x^\beta$$
Then
$$x'=x'^\nu \frac{\partial}{\partial x'^\nu}=\frac{\partial x'^\alpha}{\partial x^\beta}x^\beta \frac{\partial x^\mu}{\partial x'^\alpha}\frac{\partial}{\partial x^\mu}=\delta^\mu_{\:\:\beta} x^\beta \frac{\partial}{\partial x^\mu}=x^\mu \frac{\partial}{\partial x^\mu} $$
What am I missing here?
Orodruin said:
This is not correct unless ##x'## is a linear function of ##x##.
Are you sure? I see no assumption that the transformation need be linear in the derivation of this transformation.
smoking-frog said:
Are you sure?
I only wrote a textbook with a chapter on the subject. I am pretty sure. :rolleyes:
What you attached is the transformation rule for vector components. The coordinates are not components of a vector.
Edit: As a counter example, consider the one-dimensional manifold ##\mathbb R## with coordinates ##x## and ##y = x^3##. Then
y = x^3 \neq \frac{dy}{dx} x = 3x^3.
Those are just the coefficients, though, aren't they? ##\big( x^i \partial_i = x'^j \partial'_j \big)## does not imply ##x^i=x'^i##.
I literally took your transformation law and showed you that, in the simplest case, it would mean that 3=1. You don't have a problem with that?
Also consider the case of polar coordinates in two-dimensional Euclidean space. It is not true that ##x\partial_x + y\partial_y = r \partial_r + \theta \partial_\theta##, which would be the case if the coordinates were actually the components of a vector. For any coordinate system, there exists a vector field that has this property, but those vector fields will generally not be the same vector fields. Indeed, it is true that ##x\partial_x + y\partial_y = r \partial_r##. This has the form ##x^i\partial_i## in Cartesian coordinates, but certainly not in polar coordinates.
