Causality preserved in Klein-Gordon equation
  • Level: Undergrad
  • Thread starter Thread starter Silviu
    Causality Klein-gordon
Silviu
Hello! I am reading Peskin's book on QFT and in chapter one he shows that ##[\phi(x), \phi(y)] = D(x-y) - D(y-x)##, with ##D(x-y)## being the propagator from ##x## to ##y##. He says that if ##(x-y)^2<0## we can do a Lorentz transformation such that ##(x-y) \to -(x-y)## and hence the commutator vanishes and causality is conserved. Also he says that if ##(x-y)^2>0## we can't make such a Lorentz transformation. I am not sure how is he doing these Lorentz transformations and why you can do them in the first case but not in the second. Also, I am not sure I understand how can you do in the fist case this transformation just for the second propagator, while keeping the first one fixed.
First of all, it's always important to tell which propagator you are talking about. It's about Peskin+Schroeder Section 2.4. So here he defines ##D## to be the Wightman function (vev of a fixed-order field-operator product),
$$D(x-y)=\langle 0|\hat{\phi}(x) \hat{\phi}(y)|0 \rangle=\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{p} \frac{1}{(2 \pi)^3 2 E_{\vec{p}}} \exp[-\mathrm{i} p\cdot(x-y)].$$
This is a Lorentz-scalar field, because ##\mathrm{d}^3 \vec{p}/(2 E_{\vec{p}})## is a Lorentz scalar and all other ingredients in the integral are manifestly Lorentz invariant (with Lorentz invariant here I mean invariance under the proper orthochronous Lorentz group). Since further there is no other four vector then ##z=x-y## this implies that
$$D'(z')=D(z')=D(z), \quad z'=\Lambda z, \quad \Lambda \in \mathrm{SO}(1,3)^{\uparrow}.$$
This implies that if the claim about space-like vectors is true you have
$$D(z)=D(-z) \quad \text{for} \quad z^2<0,$$
and this implies that the vev of the commutator which is ##D(x-y)-D(y-x)## by definition, indeed vanishes for space-like ##x-y##.
Now let's prove the claim about space-like vectors. So let ##z^2<0##. Then we can always use a coordinate system, where ##z^0=0##. To see this just take ##e_1=z/\sqrt{-z \cdot z}## as one of the space-like basis vectors. The basis can be obviously constructed such that the change to this coordinate system is given by a proper orthochronous Lorentz transformation. So we have
$$z=\begin{pmatrix}0\\ z^1 \\ 0 \\ 0 \end{pmatrix}.$$
Now a rotation around the ##z^3##-axis reads
$$z^{\prime 0}=z^0=0, \quad \vec{z}'=\begin{pmatrix} \cos \phi & \sin \phi & 0\\ -\sin \phi & \cos \phi & 0 \\ 0 & 0 & 1 \end{pmatrix} \begin{pmatrix}z^1 \\0 \\ 0 \end{pmatrix} = z^1 \begin{pmatrix} \cos \phi \\ -\sin \phi \\0 \end{pmatrix}.$$
For ##\phi=\pi## you get ##\vec{z}'=-\vec{z}##, as claimed.
It's a good exercise to prove that this argument doesn't work for timelike vectors, because the sign of ##z^0## cannot be changed by a proper orthochronous Lorentz transformation (that's why it's called orthochronous).
Thank you for you answer. I am just now sure why ##D'(z')=D(z')=D(z)##. The first and the 3rd term are equal as D is a scalar field. But why does the equality in the middle holds?
By definition a scalar field obeys
$$D'(z')=D(z).$$
Now since there's no other vector involved, of which ##D## could depend, and thus you must have ##D'=D##, i.e., also ##D'(z')=D(z')##.
Another argument is that if you have no other vectors then ##z## a scalar function must be a function of ##z^2##.
