Ceiling and floor operators used for min max
  • Thread starter Thread starter quantum__2000
    Max Operators
quantum__2000
I remember seeing somewhere people using symbols for ceiling and floor operators together with super/subscripts as substitutes for min and max. Example:
\lceil x \rceil ^k
to mean min(x,k).
Has anyone ever seen this? Where? Thanks!
Mathematics news on Phys.org
I'm sorry, I haven't seen this. But I just wanted to say that this certainly ranks among the top 10 worst notations I've ever seen.
\lceil x \rceil ^k
to mean min(x,k).
I haven't seen the notation as you used it, to give the minimum of two numbers, but I have seen this:
##\lceil x \rceil##, also called the smallest integer function. It is defined as being the smallest integer that is greater than or equal to x. Many programming languages, including C, C++, and others, have a ceiling function, ceil(x), that does this.
For example, ##\lceil 1.8 \rceil = 2##.
The counterpart is the floor function, or greatest integer function, denoted ##\lfloor x \rfloor##. C, C++, and others have floor(x). This is defined as the largest integer that is less than or equal to x.
For example, ##\lfloor 2.35 \rfloor = 2##.
I agree with micromass that ##\lceil x \rceil^k## is terrible notation.
It would be a reasonable notation for denoting the smallest multiple of k greater than or equal to x. That is, the generalization of ceiling to a modulus other than 1.
Likes ElijahRockers
Yes, that's definitely incorrect notation and most people will confuse it as exponents. As someone else stated, the notation that is correct and seen in programming languages is [7.8]=8 or [5.1]=5. These are more standard and less likely to be confused.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
