Center of Mass of compound cylinder
The discussion centers on calculating the center of mass of a compound cylinder filled with two immiscible liquids, specifically mercury and water. The user derived an equation for the height of the heavier liquid (h) in relation to the total height (H) of the cylinder, given by h = H * (d2 +/- sqrt(d1*d2)) / (d2 - d1), where d1 and d2 are the densities of the heavier and lighter liquids, respectively. The conclusion emphasizes that to minimize the center of mass, the interface between the two liquids must be at the lowest point of the cylinder. Feedback from other users confirmed the correctness of the derivation and encouraged further exploration of the topic.
  • Understanding of basic physics concepts, particularly center of mass calculations
  • Familiarity with algebraic manipulation and quadratic equations
  • Knowledge of fluid density and immiscible liquids
  • Basic geometry of cylinders and volume calculations
  • Study the principles of buoyancy and stability in fluid mechanics
  • Explore advanced applications of center of mass in engineering contexts
  • Learn about the effects of varying densities in multi-phase fluid systems
  • Investigate numerical methods for solving complex fluid dynamics problems
Students and professionals in physics, engineering, and fluid mechanics, particularly those interested in the behavior of multi-phase systems and center of mass calculations.
corochena
[SOLVED] Center of Mass of compound cylinder
I have this problem. I have a cylinder filled with two liquids of different densities and not able to mix up (like oil and water). I have to fill the cilynder in such a way so that the center of mass will be located as low as possible. For example, mercury and water, cylinder radius = 1cm, height = 10cm. How much mercury and water should I use? What would be the location of the center of mass. Note: The cylinder must be filled in completely. Give a response in function of the densities of the fluids.
Hi corochena and welcome to PF,
What have you attempted thus far?
Solution
Well, I realized that the heavier substance must be located at the bottom of the cylinder and the ligther top. Then I computed the position of the center of mass of each sub-cylinder top and bottom.
Let it be:
d1: density of the heavier substance
d2: density of the lighter substance
h: height of the heavier substance
H: height of the cylinder
R: radius of the cylinder
With those I computed the center of mass of the whole cylinder and then I derivate to find the maximum/minimum and after some algebraic manipulation I came to the equation h = ( (d2 +/- sqr2(d1*d2) ) / (d2 - d1) ) * H
I realized that in order that the center of mass to be located as low as possible the center of mass must be located in the surface of contact of both substances.
I would like to know if my results are correct and other ways to solve it or any comments.
Could you be a little more descriptive with your working? Could you show all your steps?
It's a bit difficult because the simbology but I'll try:
The center of mass of cylinder 1 and 2 (heavier and lighter) are located in the middle because they are homogeneus. So I am able to find the CM of the whole cylinder:
By definition of CM:
m1 x = m2 (H/2 - x), x is the distance between CM1 and CM of the whole cylinder
m = d . V (density times volume)
m1 = d1 . pi . R^2 . h
m2 = d2 . pi . R^2 . (H-h)
so
d1 . pi . R^2 . h . x = d2 . pi . R^2 . (H-h) . (H/2 - x)
simplifying
d1 . h . x = d2 . (H-h) . (H/2 - x)
here I will make a shorcut stating that in order for the CM be as low as possible the CM must be located on the surface of contact of both substances. (The demonstration of such statement I will post it later). This statement makes the demonstration much shorter and simpler.
So x = h/2 then
d1 . h . h/2 = d2 . (H - h) . (H/2 - h/2)
rearranging
(d2 - d1)h^2 - 2d2.H. h + d2 . H^2 = 0
and solving the cuadratic we get
h = H . ( d2 +/- sqr(d1.d2)) / (d2 - d1)
I solved this problem a few months ago and I thought it was pretty interesting and I wanted to share my results and get feedback if they are correct or so.
I tried to put a picture here but I get the error that I am allowed to post URLs to other sites after I have made 15 posts of more.
Thanks corochena. Unfortunately I haven't got time to look at it now, but I'll have a good look at it later this evening.
In order to prevent spamming, users with less than fifteen posts are not allowed to post urls. However, I'm sure a mentor will approve your attachment soon.
Thanks a lot! And... how were you able to answer so quickly? Is there some kind of alarm or something?
There is a link in the top left corner called My PF, if one clicks it then it displays a list of subscribed threads.
Technically, you also make this assumption,
At the very beginning of your derivation, so you should really prove your lemma first.
I assume that your taking moments about the CM of the cylinder (C_c), in which case the above expression is,
m_1x = m_2\left(\frac{H-h}{2}\right) = m_2\left(\frac{H}{2}-\frac{h}{2}\right)
Now if one assumes that C_c = h, then the equation becomes,
m_1x = m_2\left(\frac{H}{2}-x\right)
As you originally had. However, you need to prove that C_c = h before you can use it.
Yes, I am taking moments about the CM of the cylinder Cc.
But I think m1 . x = m2 (H/2 - h/2) is wrong. The correct expression is as I wrote before (hopefully!) m1 . x = m2 . (H/2 - x). I think the new picture will explain better.
I know I have to prove that x must be equal to h/2 (that is equivalent to say that the lowest CM possible must be located at the surface of contact of the two substances).
There is another way to do it and it is not necessary to make the assumption x = h/2, but you need to find the derivative of x=f(h) to find the maxima/minima, the algebraic burden is bigger although. Result is same of course.
Also regardless the procedure and the technical details (rigor) I would like to know if somebody gets the same result and how he/she came to his/her result.
I'm afraid that I still can't see where you're deriving the following relationship from,
Perhaps I am missing something, would someone else like to chime in?
I agree. This follows from the fact that the distance between the centers of m1 and m2 must equal H/2. (The center of m1 is h/2 from the bottom; the center of m2 is (H-h)/2 from the top.)
Thanks Doc!
corochena, the rest of your derivation and your final expression for h is correct. Nicely done :approve:.
Thanks both of you. What a nice site is this! It was difficult to get someone interested in this kind of stuff, ... not anymore!
  • · Replies 40 ·
  • · Replies 97 ·
14K
  • · Replies 21 ·
