Where is the center of mass of a flat triangular plate with given dimensions?
The center of mass of a flat triangular plate with a height of 17.3 cm and a base of 10 cm is calculated using the area formula and integral calculus. The area (A) is determined to be 86.5 cm². The x-coordinate of the center of mass is found to be approximately 3.33 cm, while the y-coordinate is approximately 5.77 cm, based on the integrals set up for the triangular shape. However, the book's answer indicates the coordinates should be (6.67 cm, 11.5 cm), suggesting a potential misunderstanding of the triangle's orientation or integration limits.
  • Understanding of integral calculus, specifically the use of definite integrals
  • Familiarity with the concept of center of mass in physics
  • Knowledge of geometric properties of triangles
  • Ability to interpret and set up equations for linear functions
  • Review the derivation of the center of mass for triangular shapes in physics
  • Learn about the correct setup of integrals for calculating areas and centroids
  • Study the orientation and positioning of geometric figures in coordinate systems
  • Examine examples of similar problems involving center of mass calculations
Students studying physics or engineering, particularly those focusing on mechanics and calculus applications in determining the center of mass for various shapes.
jsr219
Find the x and y coordinates of the center of mass of a flat triangular plate of a height H =17.3cm and a base B = 10 Cm
Area = A = 1/2bh
x = 1/A ∫ x(f(x))
y = 1/A ∫ 1/2((f(x)^2)
Area = 1/2(10)(17.3) = 86.5
f(x) = 17.3-1.73x or 17.3-173/100x
... this represents the equation for the line of the hypt. of the triangle, with its y intercept at 17.3 and its x intercept at 10, and a slope of 17.3/10
All interals from 0 to 10
x = 1/86.5 ∫x(17.3-1.73x) = 3.333333cm
y = 1/86.5 ∫1/2((17.3-1.73x)^2) = 5.7666667cm
I've done this problems like these tons of time in calc and on my homework for physics, using this same method... but according to the answers in the book I'm getting this question wrong
their answer says the x,y coordinates are (6.67cm, 11.5cm)
I'm not really sure what I'm doing wrong
Please point out any mistakes I may have made
and the right direction I should be heading in
Thank you !
Is there an accompanying picture? The way the base and height are laid out would effect where the center is.
Your integral expressions are not properly written. Are you integrating with respect to x or y?
The triangle is a right triangle
The 90 degree angle is situated at the orgin... so the height follows up the y-axis or x= o
and the base follows the x-axis at y=0... more or less the height and base make the x and y axis
I intergrating with repect to x, that's why i created an equation from the line of the hypt. of the triangle. The line/equation will make a triangle with the x and y axis... or the base and height... y intercept = height of 17.3 and x intercept = base of 10
hoped I helped in clearing up questions about my approach
According to the coordinates of the cg from your book, the base of the triangle is located at y = 17.3 and the other side of the triangle adjacent to the right angle is x = 10. Are you sure of the orientation of your triangle w.r.t. the origin?
  • · Replies 25 ·
  • · Replies 57 ·
  • · Replies 20 ·
