Center of mass x-coordinate of a metal plate
To find the x-coordinate of the center of mass of a uniform metal plate with a circular hole, the approach involves calculating the center of mass of the entire plate and then adjusting for the mass removed by the hole. The dimensions of the plate are 10x12, with a hole centered at (4,0) and a radius of 2. The formula used combines the area of the plate and the area of the hole, leading to the final calculation of 2.88303 for the x-coordinate. This method effectively accounts for the uniform density of the plate and the removal of mass due to the hole. Understanding this process is crucial for solving similar problems involving irregular shapes.
cubejunkies
A uniform flat plate of metal with dimensions 10x 12 is situated in a reference plane with its bottom left hand corner at (-2, -6) and its upper right hand corner at (8, 6). The plate has a circular hole cut out of it centered about (4,0) with a radius of 2. Find the x coordinate of the center of mass of the plate.
First off, I know that center of mass between multiple particles is given by the summation of the mass times the relative location of each respective mass all divided by the sum of the masses of each of the particles, however, I have no idea how to find the center of mass of a single system, notably one that has a hole in it or is inconsistent in its mass in one dimension in some way.
I don't know how or if you can use/adapt the equation to determine center of mass of a system of particles to a single system, but if you can and this is how to find the solution, any help to let me understand how to get there would be tremendously helpful.
Thank you!
Anthony
Hint: I'll assume the plate is of uniform density. If you have that plate plus the circle, you'd have a solid plate, for which you can easily state the location of its center of mass.
Once I do that, what do I do about the circle though? I still am completely lost and don't know what to do :/
Express the center of mass of the solid plate in terms of the centers of mass of the original plate and the circle.
Thank you so much! I got it right!
I tried the problem two other ways before the attempt shown below getting it wrong, but when I finally did:
((10*12*3)-(4*4*pi))/((10*12)-4*pi) which yielded 2.88303, I was right!
Thank you so much! :)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
