How Does Angular Velocity Affect Spring Extension in Circular Motion?
The discussion focuses on the relationship between angular velocity and spring extension in circular motion, specifically for a particle of mass ##m## attached to a spring with spring constant ##k## and natural length ##l##. It establishes that circular motion is possible if the angular velocity ##\omega## is less than ##\sqrt{k/m}##, leading to the extension of the spring given by the equation $$e = \frac{\omega^2l}{\frac{k}{m}-\omega^2}$$. Additionally, the frequency of small oscillations about this circular motion is derived as $$\Omega = \omega\sqrt{4 + \frac{l}{e}}$$, indicating the dynamics of the system under oscillatory conditions.
  • Understanding of Newton's laws of motion
  • Familiarity with spring mechanics and Hooke's law
  • Knowledge of circular motion dynamics
  • Basic differential equations for oscillatory motion
  • Study the derivation of the equations of motion in circular dynamics
  • Explore the implications of varying angular velocity on spring extension
  • Learn about the stability of oscillatory systems in physics
  • Investigate the role of damping in oscillatory motion
Students and educators in physics, particularly those focusing on mechanics, as well as engineers working with dynamic systems involving springs and circular motion.
pixatlazaki
A particle of mass ##m## is placed on a smooth table and attached to a fixed point ##O## on the table by a spring with spring constant ##k## and natural length ##l##.
(i) Show that the particle can execute circular motion about ##O## with angular velocity ##\omega## provided ##\omega < k/m## , and calculate the resulting extension ##e## of the spring.
(ii) Show that the frequency ##\Omega## of small oscillations of the particle about the circular motion computed in (i) is given by $$\Omega = \omega\sqrt{4 + \frac{l}{e}}$$
$$F_s = -ke = -k(r-l) = -\frac{dU}{dr}$$
$$m\ddot{r} = mr\omega^2 - \frac{dU}{dr}$$ (from Newton's 2nd or the Euler-Lagrange equation)
$$r-l=e$$
(i). In this case, ##\ddot{r}=0##, as ##r=##const. Thus,
$$mr\omega^2 - k(r-l) = 0$$
$$kl = kr - mr\omega^2$$
$$\frac{k}{m}l = \frac{k}{m}r - \omega^2r$$
$$\frac{k}{m}l= (\frac{k}{m} - \omega^2)r$$
##r>0## and ##\frac{k}{m}l > 0## (as ##k,m,l > 0##) so for this equation to hold (and therefore, for ##\ddot{r}## to equal ##0##, ##(\frac{k}{m} - \omega^2)>0##, so ##\omega<\sqrt{k/m}##.
Plugging in ##r=l+e##.
$$\frac{k}{m}l = (\frac{k}{m} - \omega^2)(l+e)$$
$$\frac{k}{m}l = (\frac{k}{m} - \omega^2)l + (\frac{k}{m} - \omega^2)e$$
$$(\ast)\:\frac{\omega^2l}{\frac{k}{m}-\omega^2} = e $$
(ii). The radial equation of motion (plugging in ##r=l+e## once again) is
$$m(l+e)\omega^2 - ke = m\ddot{e}$$
$$m\omega^2l + m\omega^2e - ke = m\ddot{e}$$
$$\ddot{e} + (\frac{k}{m} - \omega^2)e = \omega^2l$$
$$e(t) = e_{hom}(t) + e_{part}(t)$$
$$e(t) = A\cos((\frac{k}{m} - \omega^2)t-\delta) + \frac{\omega^2l}{\frac{k}{m} - \omega^2}$$, where ##A, \delta## are some undetermined constants from the solving of the differential equation.
The (angular) frequency of ##e(t)## is then $$\Omega = \sqrt{\frac{k}{m} - \omega^2}$$
Solving ##(\ast)## for ##\frac{k}{m} - \omega^2##, we find
$$\frac{\omega^2l}{e} = \frac{k}{m} - \omega^2$$
Thus,
$$\Omega = \omega\sqrt{\frac{l}{e}}$$
Apologies for the long post. Where exactly am I going wrong?
I feel that you also need to consider the force balance in the theta direction, since, with the oscillatory motion, ##\omega## is varying with r.
Chet
  • · Replies 0 ·
