Centripetal Acceleration of hard drive
The centripetal acceleration of a rotating CD-ROM at a distance of 0.050 m from the center is calculated to be 200 m/s², assuming constant angular velocity. The initial calculation of 72 m/s² was based on a misunderstanding of the relationship between linear velocity and angular velocity. The correct approach involves using the formula ac = ω²r, which indicates that centripetal acceleration is directly proportional to the radius when angular velocity is constant. This conclusion is supported by reliable academic sources that emphasize the importance of angular velocity in such problems.
  • Understanding of centripetal acceleration (ac = v² / r)
  • Familiarity with uniform circular motion concepts
  • Knowledge of angular velocity and its relationship to centripetal acceleration
  • Ability to manipulate equations involving radius and acceleration
  • Study the relationship between angular velocity and centripetal acceleration (ac = ω²r)
  • Learn how to derive the period of rotation (T) from linear velocity and radius
  • Explore examples of uniform circular motion problems in physics textbooks
  • Practice solving centripetal acceleration problems with varying radii and constant angular velocity
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators looking for clear examples of centripetal acceleration calculations.
UMich1344
A computer is reading data from a rotating CD-ROM. At a point that is 0.030 m from the center of the disc, the centripetal acceleration is 120 m/s2. What is the centripetal acceleration at a point that is 0.050 m from the center of the disc?
ac = v2 / r
v = √[(120 m/s2)(0.030 m)] = 1.897366596 m/s
ac = (1.897366596 m/s)2 / (0.050 m) = 72 m/s2
I feel this is correct because this question appears in the section of problems that deals only with the following two topics:
- Uniform Circular Motion
- Centripetal Acceleration
I've seen this question asked before on this site and several others, and there is definitely inconsistency in how it is answered. Many people that respond consider angular velocity, which is NOT covered in these two sections of the textbook. If that was, indeed, part of the reasoning for the solution, then I would imagine the problem would have been moved to a different section by now (since this is the 7th edition of the textbook and has gone through plenty of revisions). Based on the following link, my answer is correct: http://www.physics.unomaha.edu/Sowell/Phys1110/quizzes/QuizzesSpr06/quiz7.html. This seems to be the only reliable source I have been able to find as it is from a university (not saying it's infallible) and not a forum (which often contains more false information than a site directly from a university... as I'm sure most of you would agree). This site suggests that we are to assume that linear velocity is constant when solving this problem. I agree with it.
Could someone evaluate my work and check to see if I have done it correctly? Please do not include any information about angular velocity because that concept has not been discussed neither in lecture for my course or in the textbook.
You have the relationship that
ac = ω²r
This implies directly that with ω constant
ac1 / ac2 = r1 / r2
Or
ac1 * r2 / r1 = ac2
120*5/3 = 200
Your solution is seemingly based on holding v constant which for a spinning disk is not the case, it's the ω that's constant.
If you aren't into angular velocity yet, just consider the period. T will be the same for all radii, so it is a useful thing to work with. You can find T from your velocity at the first radius using v = 2(pi)r/T
Once you have T, which applies everywhere, you can find v at the 2nd radius using the same formula. Put that in your centripetal force formula and you'll get the correct answer!
Thank you very much. I solved for T in terms of the point that is 0.030 m from the center of the disc, then plugged that value into find the centripetal acceleration at the point that is 0.050 m from the center of the disc.
The numbers worked out very nicely and it came out to be 200 m/s2, as the first response suggested.
I knew there had to be more to it, but I wasn't seeing it.
  • · Replies 28 ·
  • · Replies 20 ·
