Centripetal force throughout a vertical circle
The discussion revolves around the concept of centripetal force in the context of vertical circular motion. The original poster questions the position where centripetal force is greatest, considering various positions in the circle and the influence of velocity and gravity.
  • Participants explore the relationship between centripetal force and centripetal acceleration, with some arguing that the force is greatest at the bottom due to maximum velocity, while others suggest it is greatest at the top. There are questions about the assumptions made regarding velocity and the presence of gravity.
Multiple interpretations of the problem are being explored, particularly regarding the role of gravity and the nature of the motion (constant speed vs. changing speed). Some participants express skepticism about the correctness of the provided answer, while others seek clarification on the definitions involved.
The problem lacks specific details about the velocity and gravitational effects, leading to varying assumptions among participants. There is a recognition that the original question may have been poorly posed, contributing to the confusion in responses.
Matthew_B
In what position in vertical circular motion is the centripetal force the greatest?
Top, Bottom, Left, or Right
Can someone explain how Fc is greatest at the top?
I had reasoned that since centripetal acceleration which I will assign to a is equal to v^2/r and as a result of the velocity being greatest at the bottom the centripetal acceleration (a) will also be the greatest at the bottom
Since the formula for centripetal force is Fc= ma and the mass remains constant I said that Fc will be the greatest where the centripetal acceleration (a) will be the greatest which is the bottom.
When I received my test back I was told that the centripetal force is greatest at the top rather than the bottom can someone please explain?
The question is ill posed as it is not stated what velocity the circular motion has. If it is just subject to gravity and a constraining force, the correct answer is at the bottom.
One could also ask where the constraining force is the greatest (with constant speed or with speed given by motion in a gravitational field - in both cases the answer is at the bottom).
The problem from the test had no mention of gravity or the speed at any of the given points, however I assumed that gravity is present and the velocity is changing since the that is the type of problems we have covered in my class. Do you think then that it was indeed a problem with the key? Thank you for responding to my post also.
I wouldn't worry about it. Whoever set the test probably got their calculations mixed up.
My point is, regardless of whatever reasonable assumption you make about the velocity, the centripetal force will be greater at the bottom. The answer provided by your teacher is then simply wrong.
Aright thanks for the reply
Hang on a moment. I think you are confusing the centripetal force with the tension in the string. The centripetal force is always constant. The tension in the string will vary but not the centripetal force.
The centripetal force Fc is always mv^2/r that's made up of the vector sum of the tension in the string and gravity.
He is not confusing them. You are making the assumption that the motion is with constant speed, which clearly the OP does not.
You're right I missed that.
  • · Replies 28 ·
