Centripetal Force Washing Machine
32 replies · 25K views · last reply
UMath1
I know that the centripetal force is the resultant force which points to the center. So in the case of a washing machine, what force pushes the clothes and water to the outer edge? There is not centrifugal force, but then how come all the clothes appear to get pushed to the circumference of the washing machine.
I saw something similar in a science museum. There was a rectangular glass prism with water inside. When it rotated about its center, all the water rushed to the edge.
I asked my science teacher and he began talking about the centrifugal force. But all the textbooks I have read explicitly state that there is no such thing as a centrifugal force.
I mean initally before starting the machine the clothes are evenly distributed. Some are in the middle, some are on the edges. Once the machine starts all the clothes appear to rush to the edge. What causes them to do that?
The bottom of the washer accelerates them tangentially. The sides of the washer accelerate them centripetally. There is no centrifugal acceleration.
What you are assuming is centrifugal motion is not. It is tangential motion.
https://en.wikipedia.org/wiki/Centrifugal_force
Three-panel comic: a villain in a top hat and a stick figure strapped to a spinning centrifuge arm; dialogue argues centrifugal versus centripetal force, ending with 'No, Mister Bond. I expect you to die.'
But so there is a tangential acceleration, correct? A force does make them get pushed to the edge..right? Once at the edge however, the only force is the centripetal pulling force, right?
Also, in this video() at 2:13, what cause the pendulum to have an angle, or rather what keeps it from pointing straight down?
And what causes the ball to swing outwards in this video:
Even movement at constant speed along a tangential line would bring you to the edge.
Draw a force diagram.
Not in an inertial reference frame, no.
Remember, a force causes acceleration, so it is not enough to see that the distance between the clothes and the rim decreases. You must look to see what object is accelerating in which direction.
There is simply no object in this scenario which accelerates centrifugally in an inertial frame. Nothing gets pushed out.
But when I look at the washing machine from the outside, the clothes are initially stationary and then they accelerate to the edge. So there must be some force?
And what about the video examples in post #6?
No. They never accelerate to the edge. The accelerate tangentially and centripetally only.
That isn't true. This is a result of overteaching the idea that the centrifugal force is "ficticious". In fact, it is just a matter of choice of freference frame and what you choose to make the "action" and what the "reaction". It is called "ficticious" because it appears to arise from nowhere when viewed in a rotating frame, but it is quite real.
UMath1 said:
Tangentially to what?
To the center of the washer. As the washer starts to spin, the direction of motion (not acceleration) of everything is tangential to the center. So as the clothes start to move, they try to follow a straight line, which causes them to slam into the drum of the washer. (It is also opposed by friction, so it will really be more of a spiral).
So the tangiential acceleration appears to be centrifugal but isn't?
I feel like I (and others) just answered those questions. Can you be more specific about what is confusing you? Perhaps quote the exact passage?
Maybe the issue is mixing and matching frames. Maybe pick one and stick with it. People often prefer the inertial (non rotating) frame.
So if we stick with the inertial frame, when the machine turns on the clothes receive an acceleration tangential to the center pushing them to the edge where they experience centripetal acceleration, correct?
Suppose that the washer empty except for a single small sock which is initially at rest on the bottom of the washer. Now, the washer begins to spin CCW.
Can you describe the path of the sock in the inertial frame?
UMath1 said:
It will spin in a spiral ccw.
So if we think of CCW as the sock's path turning to the left, will the sock's path ever turn to the right in this scenario?
Exactly. So in the inertial frame the force is never centrifugal. It speeds up (tangential) and it turns left (centripetal) but never right (centrifugal).
The frame dependent inertial centrifugal force isn't part of any 3rd Law action-reaction pair.
I think I understand.
But what force is responsible for the tangential acceleration? And what about the video example in post#6?
Friction.
What is your question regarding the videos?
In the first video at 2:13, it appears that even in an inertial frame of reference the pendulum is at a slight angle and not normal to ground. Why?
As for the second video, I am not sure what is going on. My understanding is that the tangential acceleration of the key exceeds it centripetal acceleration and thus it moves farther and farther from the center. But what is the force responsible for it? I am not sure how the heavy weight is lifted. Is it because as the centripetal force increases the tension in the string increases causing a net force on the weight?
Because that's the only way the pendulum can experience a centripetal force.
To expand on AT's reply, the tension in the string supplies the centripetal force. Also, the angle looks quite steep to me, not "slight".
Yes, the tension on the string provides the centripetal force (as well as carrying the weight of both objects).
So the only way the pendulum in video 1 can receive a centripetal force is by being at angle as this allows the tension to have a horizontal component. Then, if I understand correctly, if the merry-go-round was to spin faster the angle would be greater, correct?
For video 2, as the key rotates, the tension provides it with centripetal force. But what causes more string to be pulled upwards? Is it that: when the key rotates the tension in the string increases causing a net force of the heavier weight?
Yes, there is a Newtons 3rd Law reaction to the centripetal force on the key, which acts on the string. But it's not related to the acceleration of the key, as it acts on a different body. Also note that this reaction to the centripetal force that is different from the frame dependent inertial centrifugal force (see table in the second link):
https://en.wikipedia.org/wiki/Reactive_centrifugal_force
