CERN team claims measurement of neutrino speed >c
The discussion centers around the claim made by a CERN team regarding the measurement of neutrinos traveling faster than the speed of light. Participants explore the implications of this claim for established theories such as Special Relativity (SR) and Quantum Electrodynamics (QED), as well as the methodologies used to obtain these measurements. The conversation includes both theoretical interpretations and practical concerns regarding measurement accuracy.
  • Some participants express skepticism about the validity of the measurement, suggesting that the reported 60 nanoseconds difference could be due to measurement errors.
  • Others propose that if photons were found to have mass, it would necessitate an explanation for their consistent speed at c, which contradicts the behavior of other massive particles.
  • A few participants discuss the potential implications for SR and QED, with some arguing that the existence of a tiny mass for photons might not affect these theories.
  • Concerns are raised about the methodology used to measure the distance between CERN and the detector in Italy, with some questioning how such precision was achieved.
  • There is mention of the need for further confirmation from other experimental groups before drawing any conclusions about the findings.
  • Some participants speculate about the effects of light scattering and how it might influence the propagation of photons through a vacuum.
Participants do not reach a consensus on the validity of the measurements or their implications for existing theories. Multiple competing views remain regarding the interpretation of the results and the reliability of the experimental methods.
Limitations in the discussion include unresolved questions about the accuracy of distance measurements, potential errors in the experimental setup, and the assumptions made regarding the mass of photons and neutrinos.
This discussion may be of interest to those studying particle physics, theoretical physics, and the implications of experimental results on established scientific theories.
  • #511
Centri-Fagin said:
Does anybody know if the neutrinos sent from CERN to Gran Sasso have their speed measured beofre the leave the CERN facility?
CERN shoot their hadrons around at 99.9% the speed of light?
If the neutrinos are also 'built up' to this speed then for the readings that they are getting at Gran Sasso (faster than speed of light), the neutrinos would not only travel faster than light but also be accelerating without additional energy?
That's not how it works
They have 2 syncronized clocks and a light speed baseline for the TOF
then they use the Proton Waveform and the timestamp to establish a maximum likehood function that should match the neutrino function at arrival
They take the arrival and match it and test it against the speed of light baseline.
As I mentioned above this could lead to the 60 ns anomaly being the fact that there is no magic stoper and the aditional 18 meters of the "HADRON STOPPER" being in fact a new (if less than perfect) target for the production of kaons and their decay to muon neutrinos.
  • #512
A possible experiment to confirm OPERA results:
What could happen, hypothetically, if the OPERA results were valid, and you could drop a neutrino emitter down a black hole?
  • #513
danR said:
I think you have missed key elements of the paper:
In this experiment, neutrinos seem to behave, during the 735 km travel, either as tachyons or as they had a pseudo-tachyonic behavior when transversing a material, like photons in meta-materials [9, 10] with negative refractive index or less than unity, that allows an apparent superluminal propagation without violating causality.
[emph added]
and with reference to phase velocity:
As vg > vp, the medium would cause the speed of only certain Fourier components of neutrino wavefunction in it to be larger than the speed of light in vacuum for a band of neutrino oscillation frequencies obeying the Majorana condition p ≥ kc, but seems to be forbidden by CG effect for a standard neutrino.​
Mere phase-velocity would not allow FTL communication, and the implications of the paper is that Einstein was, again, correct: nothing communicative can travel faster than c in vacuo.
I understand that the OPERA experiment measured particles velocities, which are group velocities.
A refractive index represents an interaction between a wave or a particle and matter, rocks here.
For example, the refractive index of homogeneous classical plasmas can be studied in full detail from the laws of classical mechanics and electrodynamics. The refractive index of a plasma is caused by the interaction and response of the plasma (the matter) to the wave. Usually (necessarily), this index of refraction changes with the frequency (energy), and causality then also implies an absorption of the wave.
A particle point of view or a quantum dynamics approach (necessary for plasmas below the fermi level) does not change the global picture.
In summary: a refractive index different from 1, should imply an interaction with matter as well as an absorption.
Knowing the extremely weak interaction of neutrinos with matter, I can't see how this could lead to a refractive index, even 10^-5 close to 1.
If the neutrinos have a FTL light, this can in no way be "explained" by a "refractive index".
The presence of rocks should therefore play no role in the FTL velocity of neutrino, and the same result should be expected for neutrino propagating through vacuum.
Therefore this "refractive index" is even not related to the "rocks", which is a strange syntax for a refractive index.
You could of course call v/c a "refractive index", but this would explain nothing.
I could as well say that I am driving my car at a very low refractive index.
  • #514
Just a small correction on my last comment
The distortion caused by the second target (hadron stopper) might be much bigger on the muon (initial image) sensors than on the neutrinos detected at OPERA.
I would really like to see the result of a run without the primary target T40-s, just the muon image and detected neutrinos from the Hadron Stopper.
Maybe then they would see that the difference between the 1048 ns blind calibration and their individual effects of around 1000 ns is the 60 ns hadron stopper distortion.
  • #515
Miguel,
The only delay that matters is the time elapsed between a signal on the Beam Current Transformer (BCT) and the OPERA detector in Gran Sasso.
It does not matter that the conversion from protons to kaons and from kaons to neutrinos occurs further downstream. This is because the protons and kaons have high energies and travel extremely close to the speed of light.
In particular, additional kaons that would be produced in the Hadron Stopper would in no way modify the result. Those neutrinos originating from the Hadron Stopper should come exactly at the same time in Gran Sasso than other neutrinos originating from the main target.
This is precisely the magic of the constancy of the speed of light.
But it might be challenged now.
Michel
  • #516
I assume you haven't read my last correction.
Most likely those "Hadron Stop Born" muons don't have time to decay, but there are plenty and they do show up on the muon monitors.
Furthermore not all protons have the same energy and so the fraction of speed of light they travel is proportional to their energy.
Fore-runners and laggards will skew the CBT timestamped muon "origin" picture, specialy if one assumes that the only origin of muons is at the Target (1 km before the Hadron Stop)
How does it affect the result? Maybe that's the reason they had to do a "blind calibartion" adding 1048 ns to the baseline when the explained items amounted to (in their own words) "~1000 (ns)".
Maybe it skews the medium point of decay.
It will most likely distort the picture being fitted to the "arrival" signal.
If any, or all, of these effects take place the 60 ns difference is trivial.
BTW, as a simple rule I would not consider publishing anything stating that a "blind calibration" had been used because the internal delays added up to ~1.000 and I hadn't found out why I needed 1048.
Specialy when it finishes with a 60 ns revolutionary conclusion.
  • #517
This will seem hopelessly simplistic, but aren't they saying that the neutrinos arrived sooner than light if the light had traveled the same path? How can you say that a photon leaving the neutrino source at the same moment, traveling the same path, would arrive later (or sooner) than the neutrinos? Aren't they comparing an ACTUAL measurement with a theoretical value? To say that it actually traveled faster than light would one not have to measure both the photons and the neutrinos under the same conditions?
  • #518
The thing is, they claim to know the exact coordinate distance and time the neutrinos traveled, thus if you know the distance and the time you know the velocity. It is claimed this velocity is faster than light.
Thus the questions are:
- Is the coordinate distance correct?
- Is the elapsed coordinate time correct?
  • #519
But the experiment boils down to neutrinos traveled from point A to point B in some time X. In theory, light would travel from the SAME point A to the SAME point B in some time X-n. But they can't measure light moving from the same A to B, they can only calculate what it should be, no? Without the actual measurement of light, then they can only say that the neutrinos were faster than the theoretical speed of light along THAT path. But unless they shoot a beam of photons from that A to that B, and actually measure it, their claim of super luminal speed is "on paper", as it were.
Haven't other observations of neutrinos confirmed sub-luminal speeds? Isn't it more Occam's Razorish to assume that the conditions of the experiment are the issue rather than overturning a fundamental piece of physics?
I do understand this is a very intriguing observation. Quite disruptive, one might say. It will be fascinating to watch it lay out.
  • #520
It is not possible to actually measure the one-way speed of light in any way that is consistent with Special Relativity. Neither is it possible to "calculate what it should be". What actually happens is that the one-way speed of light is assumed to be c, and a coordinate system (an inertial frame) is constructed wherein this assumption automatically holds true. The two-way speed of light (isotropy) is what can actually be measured.
That's right. In their paper, the OPERA team claims:
OPERA team said:
An early arrival time of CNGS muon neutrinos with respect to the one computed assuming the speed of light in vacuum of (60.7 ± 6.9 (stat.) ± 7.4 (sys.)) ns was measured.
  • #521
If you cannot measure the speed of light one-way, then how can you accurately transmit the information to the other end that signals the start time? If point A initiates an event, then point B needs to know the time of initiation. Basically, the neutrinos arrive before the signal of the start time, since the signal is being bounced off a satellite, or sent over a fiber optic cable or some such thing and is not traveling at c.
It must be a tricky calculation, seeing as both ends of the experiment are accelerated reference frames via the rotation of the earth. Wouldn't they they be under different accelerations based on their latitude and altitude? Wouldn't the entire path of the transmitted start signal also be subject to acceleration issues in the calculations? I assume they had to use numerical methods to do all those calculations. It would be ironic to find that the intrinsic errors in computerized floating point arithmetic caused the anomaly.
  • #522
I may be mistaken, but I believe this is a non-issue. The neutrinos violated c, not the speed of light. That should not be happening under the conditions of SR.
  • #523
Yes, I understand that now.
  • #524
Then you understand more than I as in my understanding c is the speed of light in vacuum.
  • #525
Given the small (to me it's small) amount measured beyond c, and where speed is just distance / time...
1) How is it they are so certain to the exact distance involved in this experiment ?
2) How did they rule out possibility that with the slight increase in energy density along the path of the experiment that the length did not momentarily compress by a fraction of a mm. ?
  • #526
Each relevant event is time-stamped using a clock that is located nearby, and the travel time for each neutrino depends on how the clocks at each end of the experiment are synchronized.
Yes, but they don't need to know this right away.
In fact, the time-stamps from CERN are not immediately made available to the people at Gran Sasso. They only get to see that information after they have reported the time-stamps for the neutrino detections.
Sure, its a tricky calculation for many reasons, but that's nothing that can't be dealt with given enough time and money.
  • #527
SORRY,...off by ^3 orders using calculator,.60 billionths of sec yields a non-so-small distance. Please disregard...
  • #528
How do they prove synchronization?
Is there a reason for this? Seems an odd protocol.
That's funny. Time and money can't seem to help a flailing economy. I guess physics is easier.
  • #529
Dumb question probably. But how often is the distance between source and destination in this experiment measured ? The Earth is pretty big, is it not possible that it's surface is simply flexing all the time, and that sometimes the distance between the points as a direct through-earth straight line is upwards to 60 ft less than other times ?
  • #530
In the least number of words can anyone explain for me if the results presented in paper are right or wrong. if right does it contradict the law of physics. if wrong why?
  • #531
We define the one-way speed of light in vacuum to be c as a step along the way in constructing inertial frames, but that is an entirely untestable hypothesis within the framework of Special Relativity. That is why the constancy of c has to be a postulate within the standard formulation of Special Relativity.
The two-way speed of light can actually be measured beause we can use the same clock to time-stamp emission and reception events, and therefore clock synchronization is not an issue.
  • #532
Yes , so what is your point?
  • #533
They don't. That is why the constancy of c is a postulate within the standard formulation of Special Relativity.
That helps to prevent the people at OPERA from biasing their analysis (blind/double-blind study).
Time and money only helps when it is applied intelligently.
  • #534
To demonstrate the difference between c as an untestable definition (postulate), and 'the speed of light' as an actual measurement.
  • #535
ChrisPhy said:
...how often is the distance between source and destination in this experiment measured ? The Earth is pretty big, is it not possible that it's surface is simply flexing all the time, and that sometimes the distance between the points as a direct through-earth straight line is upwards to 60 ft less than other times ?
They measure this distance constantly. You should look at the paper (start with Fig. 7).
OPERA said:
The high-accuracy time-transfer GPS receiver allows to continuously monitor tiny movements of the Earth’s crust, such as continental drift that shows up as a smooth variation of less than 1 cm/year, and the detection of slightly larger effects due to earthquakes. The April 2009 earthquake in the region of LNGS, in particular, produced a sudden displacement of about 7 cm, as seen in Fig. 7. All mentioned effects are within the accuracy of the baseline determination. Tidal effects are negligible as well.
  • #536
No.
...if right does it contradict the law of physics. if wrong why?
It right, then it would be something new, but nobody knows for sure whether the result is right or wrong. It will have to stand up to the test of time before anyone can know that.
  • #537
Thanks, I didn't even know the paper was available. Thanks.
  • #538
! - disregard::
Just read the released PDF regarding results. Thanks. The document contained enough detail for me to understand the methodology of how the timing was accurately 'synched' however details of how the distance between the points is confidently accurate is missing. The paper simply makes the assertion that the margin of error is 20cm. Accurate distance calculations are probably considered second nature to most and that's why it wasn't mentioned, but does anyone know the details, specific details, of how this distance is determined to within 20cm (please don't tell me it is the inverse, by measuring how long signals take between the two assuming c, because then we may just simply be looking for why these signals were slightly SLOWER than c) Can someone help me understand. Thanks
  • #539
Sorry, I re-read the intro again, and it contained numerous mentions of the 'dedicated geodesy campaign' and a brief explanation, I'll do some research on the precise methods elsewhere, sorry too quick to ask... Disregard last question.
  • #540
Indeed.
Seems to be working, too, wrt blind/double-blind... IMO.
It sure looks like somebody isn't seeing... :rolleyes:
OCR... lol
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 19 ·
