NTesla
- 263
- 27
I'm struggling to understand what you mentioned by "it's top" when you mentioned that "the chain is constrained not just by the bottom of the tube, but also by it's top and right."jbriggs444 said:The drawing shows the chain descending vertically. Not in some sort of [evolving!] parabola. This implies that the chain is constrained not just by the bottom of the tube but also by its top and right where the tube turns downward at its mouth.
If the chain fell in a curve then the length of the falling portion would not be ##h##.
Here's what I understood by your statement: The element of the chain which is just at the bend, would experience a leftward force (I agree on this point). However, your statement implies that the element would also experience a downward force by the top of the mouth. And the bottom of the tube is already supporting the weight of the horizontal part of the chain.
So, if we consider the hanging part of the chain, then it is experiencing 4 forces:
(1) Due to the weight of the hanging part of the chain: ##\lambda hg(-\hat j) ##
(2) Force exerted by the table on the element which is just touching it and is coming to rest: ##\lambda \frac {\Delta x}{\Delta t}v (\hat j)##.
(3) Force exerted by the top of the mouth of the tube on the element which is just at the bend of the tube: ##\lambda \frac {\Delta x}{\Delta t}v (-\hat j)##.
(4) Tension force due to the horizontal part of the chain = ##\lambda h(g - \frac {\Delta v}{\Delta t})(-\hat j)##.
Is that correct ?
