Chain Rule with Partials & Evaluation Question
  • Thread starter Thread starter Alex Bard
    Chain Chain rule
The discussion revolves around the application of the Chain Rule in multivariable calculus, specifically focusing on partial derivatives and their evaluation. The original poster presents two parts of a problem involving functions of two variables and their transformations.
  • The original poster attempts to apply the Chain Rule to find partial derivatives, expressing confusion about the setup and notation in part B. Some participants question the clarity of the notation and the correctness of the derivatives calculated. Others suggest re-evaluating the expressions and clarify the definitions of the variables involved.
Participants are actively engaging in clarifying notation and correcting mathematical expressions. There is a focus on ensuring that the derivatives are computed correctly, with some guidance provided on the proper application of the Chain Rule. Multiple interpretations of the problem are being explored, and while there is no explicit consensus, the discussion is productive.
There are indications that some participants feel that parts of the problem may be missing or unclear, particularly in part B. The original poster expresses uncertainty about the completeness of the question posed.
Alex Bard
Hi, I have a test prep question regarding Chain Rule, please see the problem and my attempt below. I believe part A is okay but part B, I'm just confused, seems like there is a part missing from the question, or at least how I'm use to doing it.
[itex]A. Let f(x, y) = cos(xy) + ycos(x), where x = u^2 + v and y = u - v^2. Find \frac{∂z}{∂v} when u = 1, v = -1.[/itex]
B. Let f(x,y) = ln(x - 3y). Find f(6.9, 2.06)
Chain Rule is stated by [itex]\frac{∂z}{∂x} * \frac{∂x}{∂v} + \frac{∂z}{∂y} * \frac{∂y}{∂v}[/itex]
Part A.
[itex]frac{∂z}{∂v}[/itex] = cos(xy) + y cos(x)
First take the partial in respect to x and multiply by partial to respect to v
= (y)[-sin(xy) - y sin(x)] (2u + v)
Take partial in respect to y and multiply by partial in respect to v
= (x)[-sin(xy) + cos(x)] (u - 2v)
Add both of them to complete:
= (y)[-sin(xy) - y sin(x)] (2u + v) + (x)[-sin(xy) + cos(x)] (u - 2v)
Now, I substitute the values of x & y with their respective counterparts:
= (u - v^2)[-sin((u^2+v)(u-v^2)) - (u-v^2)(sin(u^2+v))] + (u^2+v)[-sin((u^2+v)(u-v^2)) + cos(u^2+v)](u-2v)
Now I will plug in the respective values for u & v with their respective counterparts:
= (1 - (-1)^2)[-sin((1^2+(-1))(1-(-1)^2)) - (1-(-1)^2)(sin(1^2+(-1)))] + (1^2+(-1))[-sin((1^2+(-1))(1-(-1)^2)) + cos(1^2+(-1))](1-2(-1))
Now to simplify and Solve:
= (0)[-sin((0)(0)) - (0)(sin(0))] + (0)[-sin((0)(0)) + cos(0)](3)
= 0 + 0 (3)
so the answer I get is 0.
Does that seem right?
Part B.
Let f(x, y) = ln(x - 3y). Find (6.9, 2.06)
I believe this problem is missing a point but considering this problem as is, I got:
Find f(6.9, 2.06) = ln(x - 3y)
→ (6.9 - 6.18) = 0.72 → ln(0.72) ≈ -0.33
Now zx = [itex]\frac{1}{x - 3y}[/itex]
Now zy = [itex]\frac{-3}{x - 3y}[/itex]
so my final answer is
[itex]\frac{1}{.72} , \frac{-3}{.72}[/itex]
Thank you for your help.
I'm unsure of your notation, which makes it hard to answer. By ##\int(x,y)## do you mean f(x,y) a function, and not an integral? And do you then mean z = f(x,y)?
Yes sir, for some reason seeing the integral sign at first looked like a f to me, as in function. Fixed the notation.
and
Alex Bard said:
Let f(x, y) = cos(xy) + y cos(x)
f(x, y) = [-sin(y) - y sin(x)] * 1 + [- sin(y) + 1 * cos(x) + y-sin(x)] * (-2v)
You've lost me already. You don't mean f(x,y) on the LHS, right? Some derivative of f? Even then, I don't see how you get the RHS, e.g. how you would get any sin(y) term. Pls fill in the gaps.
Apologize for the messiness, I rewrote and did my best to follow the brackets and (), please let me know if it doesn't make sense for me to go back and clean it up even further.
Alex, assuming z = f(x,y) did you mean your next line to be dz/dx which would be ##f_x(x,y)##? Because you wrote f(x,y) again. And if you did mean it to be ##f_x(x,y)## it isn't computed correctly. There could not be a sin(y) in that derivative. Pretend to begin with that the "y" is a 2 and it may be clearer how to take this derivative.
Until this much is sorted out, we can't go on to the next step.
Sir, I believe I've cleaned it up right before your comment. Per haps it looks better now? Let me know if its still messy and I will attempt to break it up. Also, you are correct, i did mess that part up and re-did my math as a result. Thank you for bringing it to my attention.
Alex Bard said:
A. Let ##f(x, y) = \cos(xy) + y\cos(x)##, where ##x = u^2 + v## and ##y = u - v^2##. Find ##\frac{∂z}{∂v}## when u = 1, v = -1.
That gives you a term -y2 sin(x) on the left. Looks like a factorisation error.
And ∂x/∂v is not (2u + v).
You are now on the right track. However your ##∂x/∂v## and ##∂y/∂v## are not computed correctly.
Okay, I see that it should be (2u + 1) in ∂x/∂v
and I see, it was an ill placed bracket, the y should NOT be distributed across both terms. It should be:
= [(y)-sin(xy) - y sin(x)] (2u + v)
Am I correct in both of those assessments?
No, your ∂x/∂v is still wrong. What, by definition, is ∂u/∂v?
And I hope you mean [-(y)sin(xy) - y sin(x)]
∂u/∂v means the change in u in respect to change in v.
But isn't it ∂x/∂v? As in the change in x in respect to v? so it would be just 1? considering the u^2 is a constant it would be 0 and v would become 1, correct?
Yes! ∂g/∂v means the change in g in respect to change in v if u is held constant. So by definition ∂u/∂v = 0.
Okay, so in that respect, this is what the problem should look like.
Let f (x, y) = cos(xy) + y cos(x);
= [-y sin(xy) -y sin (x)](1) + [-x sin(xy) + cos(x)](-2v)
substituting u & v for their respective values of x & y:
= [ (-u-v^2)(sin((u^2+v)(u-v^2)) - (u - v^2) sin((u^2 + v)(u - v^2))] + [(-u^2+v) sin(u-v^2) + cos(u^2+v)](-2v)
substituting the given values of u & v with solved x & y values:
u = 1
v = -1
x = u^2 + v = 1^2+(-1) = 0
y = u - v^2 = 1 - (-1)^2 = 0
= [(-2) sin((0)(0)) - (0) sin((0)(0))] + [(-2) sin(0) + cos(0)] (-2(-1))
sin(0) = 0
cos(0) = 1
= cos(0)(-2v) = 1 * (2) = 2
= [-y sin(xy) -sin (x)](1) + [-x sin(y) + cos(x)](-2v)
You've lost a factor y in the sin(x) term, and the next term is wrong too.
If we're ever going to get through this you will need to be more careful with the algebra.
Edited the above post for correction. Thank you for point out my mistake and I will be more careful going forward.
Sign errors. -a-b is not the same as -(a-b).
Missing x factor inside.
Thank you for your help and I believe I got the problem already solved on paper, just do not know how to mark the post as SOLVED as I can't edit my original Post
Yes, it would be handy if there were some status flag the originator could turn on to say the thread is finished with. Another flag requesting more help would also be useful. Sometimes people post to their own ignored thread saying 'bump', but that's easily missed.
