Charging 18650 Batteries for Safe Setup and Usage
  • Thread starter Thread starter Biycchu
    Batteries Charge
13 replies · 3K views
Biycchu
Hello Friends,
Please help me to setup 5 [18650] Li-Ion battery of 11.1 volt
I describe everything in image.
Please check attach file
Thanks in Advance
Not possible without having one battery destroyed when in use or charging. Find another use for the two extra batteries.
Biycchu said:
Hello Friends,
Thanks in Advance
You could put all 5 batteries in series and use an efficient buck topology DC-DC converter to get you back down to the 11V. But I'm guessing that you don't have experience designing and building DC-DC converters?
I know i am a nonsense guy. Please check my 2nd attach file. Help me once again and I will not ask you again for any kind of help in this post.
Sir I don't want to spend money spend mony on multimeter & dc to dc convert. I already bought a soldering iron which not heating perfectly and seller refused to return it. Also I bought a 12 volt 9 watt bulb dc which is working correctly.
I have insert all of 5 18650 battery from my damage power bank.
Um, how did it get damaged?
You can only parallel-connect batteries when they are well-matched. They would need to be the same age with the same charging history.
It seems like you are trying to do something pretty dangerous. What are you doing with these Li-Ion batteries? Are you familiar with the fire risk when working with batteries, especially Li-Ion batteries?
Do you have 5 batteries or 6? Sometimes you say or draw one and sometimes the other.
Oh, and I am sorry your soldering iron is no good, but we're really not responsible.
I have 5 batteries sir. In the above reply Mr. berkman said to arrange 1 another battery that's why I wrote 2nd note.
All of batteries are ok. Only circuit board was damaged then I was think to convert it into dc light. Also I have a 10 watt solar panel and I am using it to charge my 11.1 volt batteries.
You didn't answer this part of my reply. Please give us explicit answers to my questions or your thread will be closed. Thank you.
I must repeat the warning about connecting batteries in parallel unless they are properly matched. They can destroy each other and overheat. You could well be better off using just three at a time in series. If, as you suggest, you have no meter and you don't really want to get involved with additional circuitry then that may be the best solution, although it would mean half the available mAh.
Take care!
My english is very weak because I passed 10+12 exam from a bengali medium school. after 12th passed, I completed my graduation (in bachelor of arts) from english medium university and here is the end of my study. I don't gave importance on english. but now I will spend some days to learning on english========[I will update this thread with my working process, if you agree then]=======
I am decided to make litium ion battery pack via 18650 battery upto 18ah - 20ah
Today I order this from amazon (xcluma 5A 75W Xl4015 Cc Cv Dc-Dc Lithium Battery Charger Step-Down Module)
I have solar panel also my lg monitor is 19 volt
Remaining items to buy:-
1. multimiter
2. 3s bms
3. 60 watt soldering iron
4. 10000 mah branded litium ion power bank for 18650 battery (it's a best idea to buy 18650 battery in cheap price)
If I am wrong then please correct my
Thread closed temporarily for Moderation per safety concerns...
UPDATE -- After a Mentor discussion, this thread will remain closed. @Biycchu please find a local Mentor where you live that can help you with projects like this. Projects like this are not safe to do on your own with your current lack of experience.
