Check if a scalar is an eigenvalue of a matrix
To determine if the scalar λ=1 is an eigenvalue of a matrix A, it is necessary to find a non-zero vector v such that Av=λv. The discussion clarifies that from Av=v, one cannot conclude A=I, since this only indicates that v is a solution to the homogeneous system (A-I)v=0. If A-I is invertible, the only solution is v=0, while if it is not invertible, there can be non-zero solutions as well. An example is provided where a non-identity matrix A has eigenvalue 1 with specific vectors. Ultimately, λ is not an eigenvalue of A if the only solution is the trivial one.
danielpanatha
We have a matrix Anxn (different than the identity matrix I) and a scalar λ=1. We want to check if λ is an eigenvalue of A.
As we know, in order for λ to be an eigenvalue of A, there has to be a non-zero vector v, such that Avv
Avv
Av=1v
Av=v
A=I
But we know that A is different than I, so λ is not an eigenvalue of A.
Is my attempt right?
Thanks in advance for your assistance.
Avv
Av=1v
Av=v
A=I
Your last equation is nonsense. From Av = v you cannot conclude that A = I. All you can conclude is that v must be a solution of the homogeneous linear system (A-I)v = 0.
RGV
In particular, the only operations defined on a vector space are addition of vectors and multiplication or division by a scalar. You cannot "divide both sides" by a vector.
(If Av=Bv for all vectors, v, then you can conclude that A= B. But not if Av= Bv for some vector, v.)
In other words, you can't divide both sides of the equation by the vector v. Linear operators like \underline A may be written down using matrices and said to operate on vectors through matrix multiplication, but what's really going on is that A is a linear function, which is why trying to factor v from both sides is nonsense.
Eigenvalues satisfy the characteristic equation that \det (\underline A - \lambda \underline I) = 0.
(PS. In particular, a linear operator acting on a vector has a general form \underline A(v) = (v\cdot e_1)a + (v \cdot e_2)b + (v \cdot e_3)c + \ldots{} where a,b,c are vectors. Unless you know something about the structure of the operator, dividing both sides by a vector doesn't give you anything useful.)
Thank you all for your replies.
One last question:
If we think of this theoretically, in the equation Av=v, there has to be a matrix A that will be multiplied by v and the result will be the same vector v. I understand that we cannot divide both parts of the equation by v, but could you please give me an example with a non-identity matrix A and a non-zero vector v that satisfy the equation Av=v?
Sure. Consider a linear operator on \mathbb R^4.
\underline A(e_1) = e_1 \\<br /> \underline A(e_2) = -e_2 \\<br /> \underline A(e_3) = e_3 \\<br /> \underline A(e_4) = -e_4
Any linear combination of e_1, e_3 is an eigenvector of this operator with eigenvalue 1.
Thank you!
$$A = \begin{bmatrix}1 & 1\\ 0 & 1 \end{bmatrix}$$
$$\lambda = 1, v = \begin{bmatrix}1 \\ 0 \end{bmatrix}$$
Thanks!
If (A - I)v = 0, what condition needs to be satisfied in order for v not to have the trivial solution v = 0?
Chet
Chet
If A - I is invertible, the only solution is v = 0.
If A - I does not have an inverse, then v = 0 is still a solution, but there are also nonzero solutions.
So in both cases, v = 0 is a solution. The only difference is whether that is the unique solution or it is one of an infinite number of solutions.
You can tell whether a square matrix is invertible -- its determinant is nonzero. If an inverse does not exist, the determinant is zero.
Thanks Mark. That was the response I was trying to elicit from the OP.
Chet
Yes, but you phrased it poorly- by leaving out a single word! You said, "If (A - I)v = 0, what condition needs to be satisfied in order for v not to have the trivial solution v = 0?"
v= 0 is, as Mark44 said, always a solution. What you meant to say was, "If (A - I)v = 0, what condition needs to be satisfied in order for v not to have only the trivial solution v = 0?"
Notice, by the way, that the "eigenvalue" question is "existence and uniqueness" turned on its head. A solution, the trivial solution, always exists for the equation Av=\lambda v. \lambda is an eigenvalue if and only if that solution is NOT unique.
  • · Replies 33 ·
  • · Replies 29 ·
  • · Replies 69 ·
9K
