Chem/phys question not sure what this is
  • Thread starter Thread starter quantumlight
The discussion revolves around the behavior of Pb-212 ions in a saturated PbCl2 solution, highlighting the dynamic nature of chemical equilibrium. When Pb-212 is introduced, it replaces some of the normal Pb2+ ions in the solid PbCl2, demonstrating how isotopes can influence equilibrium. The equilibrium between solid PbCl2 and its dissolved ions is not static, as both dissociation and crystallization processes occur simultaneously. The participants clarify that the correct oxidation state of lead in this context is 2+, not 3+. This illustrates the complexities of isotopic interactions in nuclear chemistry.
quantumlight
ok this is in my Nuclear chemistry section (go figure)
a small amount of Pb-212, in the form of 3+ ion, is injected into a saturated solution of PbCl2 that is in contact with the solid salt. A short time later some of the Pb-212 is found in solid PbCl2 in the saturated solution. What does this information tell you about the nature of the equilibrium between solid PbCl2 and its dissolved ions?
i would assume the solvent is water
PbCl2(s) + H2O(l) <----> Pb2+(aq) + 2 Cl-(aq)
so since some PbCl2 would dissociate while others use the seed salt to crystallize the dissociated normal Pb 2+ would be replaced by the isotop Pb 212 so i guess the equilibrium illustrates the natural composition ratio of different lead isotopes
im just guessing here since knowing that the chapter is nuclear chemistry and the amu average of different elements couldn't possibly be obtained by finding all of the isotopes in the universe
You sure the question states Pb3+? Or is it a typo?
Is chemical equilibrium static or dynamic?
Borek
oops yeah its 2+ uhmmm its dynamic
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
