Circuit Design for Automatic Dustbin Lid Opening | Science Project
The discussion centers on designing a circuit for an automatic dustbin lid opening mechanism triggered by a person's presence. The proposed circuit includes a proximity sensor, such as an ultrasonic or infrared sensor, connected to a microcontroller that drives a servo motor. Alternatives include directly wiring the sensor to a servo driver circuit or using a DC motor with limit switches for simplicity. Additionally, components like Fresnel lenses and Passive Infrared (PIR) sensors are suggested for effective people detection.
  • Understanding of proximity sensors, including ultrasonic and infrared types.
  • Familiarity with microcontrollers and their interfacing with motors.
  • Knowledge of servo motors and their control mechanisms.
  • Basic electronics skills, including working with DC motors and limit switches.
  • Research how to implement ultrasonic sensors with Arduino microcontrollers.
  • Learn about controlling servo motors using PWM signals.
  • Explore the use of Passive Infrared (PIR) sensors in automation projects.
  • Investigate the application of solenoids in mechanical systems for lid opening mechanisms.
This discussion is beneficial for electronics enthusiasts, hobbyists working on automation projects, and students interested in circuit design and robotics.
Pranav Jha
hi everyone! for my science project, i want to create a circuit which automatically opens the lid of a dustbin when a person passes by the dustbin. Is there a particular type of circuit that i can use to accomplish this?
What do you mean by particular type of circuit?
The general idea would be something like -
proximity sensor --->Microcontroller--->servo motor driver-->servo motors.
Proximity sensor, like an ultrasonic sensor or infrared sensor etc would sense the person and send a signal to a Micro.
Micro would then drive a servo motor thru a servo drive circuit. The servo motor would open the lid.
You could eliminate the Microcontroller and wire the sensor directly to the servo drive circuit.
haven't worked with servo motors yet. Could you give me the name of sites that would be a good place to start off one's experience with servo motors?
Even simpler than a motor, use a solenoid from your old washing-machine to open the lid.
Also look for Passive InfraRed (PIR), like your porch light thing-a-ma-bob, and close range IR sensors to trigger the thing. Once again I recommend sparkfun.com ...
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
  • · Replies 32 ·
  • · Replies 51 ·
