Circuit problem with ammeter and unknown resistance
76 replies · 14K views · last reply
Femme_physics
http://img811.imageshack.us/img811/6902/circuittosolve.jpg
This circuit includes 4 resistors whose value of 3 of them is known and the forth resistor, Rx is unknown. They connected an ammeter A to the circuit and the current through it is 0.
1) Calculate Rx.
Is the value of Rx depends on the ammeter resistance A? Explain.
2) Write the name of the circuit
I seem to be getting way too many unknowns!
Rx = unknown
I0 unknown
I1 = unknown
I2 = unknown
V = unknown
I'm not sure how to derive more equations. Or how to use the ammeter. If I'm told it has 0 current, than it must have 0 voltage, and must have 0/0 resistance! So, how do I even treat it? And why do they mean by the "name" of the circuit? I personally named him Electrobob before I started the exercise and I refuse to change it!
http://img810.imageshack.us/img810/7382/toomanyunknowns.jpg
Well, it is a very well known "bridge" circuit, used to measure resistance, try to find its real name.
There is a mistake in your third equation. You wrote Rx instead of R3.
Zero current across the ammeter means zero potential difference across its terminals. How are the potential differences across R1 and R2 related?
ehild
Rx = unknown
I0 unknown
I1 = unknown
I2 = unknown
V = unknown
Well you didn't draw a loop yet at the top along the ammeter...
That would give you the extra equation you need.
Indeed, from this you can not deduce the resistance.
However, an ammeter is designed to measure the current through a wire.
To do that it's not supposed to alter the current, so its resistance must be very low.
You can treat it as a short circuit, that is, having a resistance of zero.
I like your name! :smile:
Electrobob it is!
Those ammeters which are designed to read very low currents and detect balance at zero current, usually do not have very low resistance. It can be a few hundred ohms.
ehild
ehild
@ehild: Thanks :)
I didn't know that yet.
@FP: Either way, you do not need to know the resistance.
Since the current is zero, the voltage across it is zero, so its contribution to the voltage law is zero.
Oh! I see. Wiki's been a dear :) It's Wheatstone bridge!
That's what you get when you copy-paste :-/ Thanks!
You mean that they're parallel and I should combine them like parallel resistors?
But what's the point of drawing a loop through the ammeter of no current goes through it?
I like your name!
Electrobob it is!
*chuckles*
I'm afraid that won't help you.
It's not about the ammeter, it's about the voltage law equation with I1, R1, I2 and R2.
Yea, I didn't think it would. I was just wondering what ehild means.
That would give me a 4th equation. But, I have 5 unknowns. I should need 5 equations, right?
Not in this case. You'll see... :smile:
Nice job! Old people used to learn about it and doing lab measurement as students "Measuring resistance with Wheatstone Bridge".
:) I do the same mistake quite often.
If you want to calculate the current through the battery you can consider R1 parallel to R2, Rx parallel to R3. But you do not need that. You have to calculate Rx. Use the information given, that the current is zero through the ammeter. Write the loop equation for the ammeter circuit.
ehild
Are you familiar with the concept of the voltage divider where there are two resistors in series placed across a potential difference (say a battery) and the potential at the 'tap point' where the resistors meet is a portion of the applied potential that depends upon ratios of the resistor values?
If so, can you recognize two such voltage dividers in your Wheatstone Bridge circuit?
I meant to reply sooner but I got cut off internet connection for a bit.
ehild
Fair enough.
Okay.
The red arrows are suppose to indicate the loop to which I'm considering KVL-- I'm perfectly aware there's no current flowing through the ammeter section!
http://img269.imageshack.us/img269/6941/cirmh.jpg
Is that right?
That's how "you" learned about that? Not that I'm saying you're old.. you're saying...said..er... *embarrassed*
Makes perfect sense. Doesn't that come from parallel connection of resistors?
Well, yes, R1 and R2! I believe.
Is that right?
That's fine, the arrows do not have to match the actual current.
They're only defining which way you have chosen to be +.
But no, it is not right.
With your choice for the loop you have forgotten the voltage source. :wink:
That's fine. I've got cut off as well.
Right. My bad. But, other than that I got it right. Now I can only use the counterclockwise loop with the ammeter (I presume that's what sophiecentaur meant when he asked "and the two other resistors?").
That would get me yet another equation. This is the most equations with the most unknowns I ever had to solve in my life!
Is it always like that in electronics? And, is that the only way to solve this problem? Ohm's law appears to be completely useless in getting the answers.
Wow, you really are a Jew.
LOL sorry...^^ :)
Well, you could have done with 1 equation less, but oh well. ;)
And no, gneill and sophiecentaur meant something else.
It's another way of reasoning out the answer.
I didn't mention that way yet, but was planning to come to it, when you were done with Kirchhoff. I just didn't want to confuse you...
Either way, it's good practice for setting up equations and solving them. :smile:
Well, you're applying Ohm's law each and every time you're applying Kirchhoff's voltage law. :smile:
And we'll get back to Ohm's law in a minute with an easier way to find the answer.
LOL sorry...^^ :)
Uhh? Is that a reference to the Jewish birth ritual? :confused:
Is that right?
There is no current through the ammeter so no voltage across it, but you included the battery in the circuit. Why don't you use the much simpler red loop?
I learned about Wheatstone bridge at high school first, more than fifty years ago, and later at the university, and later I taught it... but I am not at all old :smile:
ehild
  • Wheatstone bridge circuit diagram with an ammeter across the top branch between nodes D and B, resistors R1 and R2 on the upper arms, R3 and Rx on the lower arms, and a battery between A and C. Values: R3 = 3.2 Kohm, R2 = 5.1 Kohm, R1 = 1.7 Kohm.
:) I see.
I'll go at it step by step then.
I'll start with the equations.
How can I use this loop if it has no voltage source?
KVL states: "The directed sum of the electrical potential differences (voltage) around any closed circuit is zero."
Voltage! There must be voltage source in a KLV loop, no?
Right, but I didn't directly solve it with the voltage drop methodology (what's the official name for this solving tactic? it can't be "ohm's law" since "ohm's law" just represent the formula, not a solving methodology).
LOL was it silly? I really should silly slap myself over that. Seriously, every time I make a pun a kitten dies.
:) Old is how you feel, anyway!
Femme_physics said:
:) I see.
Finally! :smile:
Don't make me *command* you again! :wink:
Hmm, I don't see anything about the KLV loop needing to have a voltage source?
It only talks about voltage differences in general I think... :rolleyes:
Uhh... I dunno. :confused:
I have to admit I just invented the term "Voltage drop methodology" myself, I thought it sounded sort of cool. :cool:
Basically they're all variations of applying Ohm's law. I'm not aware of any names for methodologies here...
Well? Did you? Silly slap yourself I mean? :smile:
Now do you understand what I mean with RPGSM?
No.
You are just applying Kirchhoff's circuit laws. see: http://en.wikipedia.org/wiki/Kirchhoff's_circuit_laws.
ehild
No.
ehild
But where is the voltage difference from? I'm used to seeing a plus and a minus when I use Kirchhoff's circuit laws. I don't see a plus and a minus designated in ehild's red-marked loop. That's confusing.
Uhh... I dunno.
I have to admit I just invented "Voltage drop methodology" myself, I thought it sounded sort of cool.
Then I'll call it that too until someone correct me ;) Stuff "you" invent are always cool! And if you give it you ILS seal of approval, it's in my mind as though the science counsel approved of it officially :)
Are you enjoying my self-RPGSM?^^
*smacky-slappity-slap-slap*
The fact that you're looking at an isolated loop doesn't mean the rest of the circuit isn't there anymore. It's just that for any loop, with or without voltage source, KVL must hold.
You don't need a plus or a minus.
What you need is a drawing of the entire circuit, marked with the currents and the direction you have chosen for those currents.
Note that in a loop the currents do not even have to point in the same direction.
With this you can choose any loop and apply KVL, taking into account the proper plus or minus depending on the chosen direction of the currents.
:blushing:
(Be careful! You're making me feel like an expert, and I haven't even made it to homework helper yet!)
Yep! :smile:
You had that one coming!
Something that may simplify your life a bit is to recognize that, anytime that you know that a branch of a network is passing zero current, that branch can be ignored (simply remove it from the diagram!) as far as loop equations are concerned (This assumed that the branch contains finite valued components -- no open switches or infinite resistors!). Further, if the branch is passing zero current then you know that the the two nodes where the branch connects must be at the same potential (so that there's no potential difference that would make current flow in the branch).
In this problem you are told that the ammeter is passing zero amps; there;s no current. So, removing the ammeter and labeling the points where it connected Va and Vb, we conclude that Va must equal Vb. The trick then is to find Rx that makes this happen.
There are a few possible approaches to this. In one approach you write loop equations for the two obvious loops (Battery--R1--R3--Battery; Battery--R2--Rx--Battery), solve them for currents and determine expressions for Va and Vb. Equate Va and Vb, solve for Rx.
In another approach you spot right away that there are two independent voltage dividers operating and that the calculation of Va and Vb can be written directly by inspection.
Moreover, once you recognize that it's voltage dividers at play and that they should have the same potential, and knowing how the 'tap' potential of a voltage divider depends only on the ratio of the resistor values forming the divider, then you can write the expression for Rx immediately, too!
Here's the circuit diagram redrawn to accentuate the loops and dividers I mention. The ammeter has been "deleted" because it draws no current when Va = Vb.
  • Circuit diagram with a battery V in the centre and two loops, each with a series resistor (R1, R3 on the left; R2, Rx on the right), with terminals Va and Vb labelled on the outer sides.
I'm going to class soon, but I will write your replies on paper (I wish I had a printer at work) to read it on the bus and I'll probably get back to you probably only tomorrow morning since I'll be too tired to reply tonight. Thanks for your time and effort, gneill, ehild, ILS (also sophiecentaur). You're all amazing in helping me through this. Electronics is a fascinating and beautiful science.
Kodus! And BBL :)
I eventually fell asleep on the bus, but I did copy your entire reply to paper. :) [this is what you do when you have no iphone! :( ]
(proof!)
http://img5.imageshack.us/img5/7664/proofsk.jpg Now it's morning so I'm ready to take a deep breath and look at this exercise again.
Really? Okay, then I've just drawn a circuit. If I use KVL on this drawn loop, does it mean the V I should get in the sum of all V is in fact the V after R1 voltage drop. Its plus end is B, its minus end is C. Hmm... if I'm right then things are beginning to make a bit more sense.
http://img29.imageshack.us/img29/2674/10vyc.jpg
http://img832.imageshack.us/img832/7233/sigmav.jpg
But now we've reduced the problem to 2 equations, 2 unknowns. I'm confused, you and ILS are saying two different things it seems to me. I should keep the ammeter and get enough equations, or I should remove the ammeter and not get enough equations. What ILS says seems to make a bit more sense to me. Isn't it best if I use the ammeter so that at least gives me the number of equations I need?
2 equations are not enough equations!
Rx = unknown
I0 unknown
I1 = unknown
I2 = unknown
V = unknownhttp://img818.imageshack.us/img818/2139/correctedequ.jpg
(proof!)
I really like these pictures! :smile:
The V should not be part of your equation, since the voltage source is not in the loop.
And could you draw the currents I2 and I3 too?
That is, labeled arrowheads in the wires?
I ask because I think the signs of the currents mismatch what you intended.
I'd suggest to keep the ammeter in for now.
Then you should have 4 equations (of which 1 is unnecessary).
And you should have 5 unknowns (of which 1 is unnecessary).
Normally, you wouldn't be ables to solve this, but you'll find that 1 unknown cancels out when you try to solve it.
Could you make a list of all the relevant equations?
Femme_physics said:
Looks right to me. looks right to you?
Almost. ;)
I'm afraid that in equation #4 you've got the sign of I2 wrong.
And I see you've included a 5th equation.
All right.
Well, I'm afraid in this one you've mixed up the resistors and the sign of I2 is wrong.
Could you label the resistors and the currents in each wire?
As far as I'm concerned there's no need to show all the drawings now.
I already know them.
Just 1 drawing will suffice with resistors and currents drawn and labeled (currents with the chosen direction as with an arrowhead).
Note that I do not mean the arrows that you've drawn to indicate the loop.
Femme_physics said:
Hmm...are you telling me that in a loop, a current can go in opposite directions? Such as in here (current indicated in red, loop in blue)
Yep! You've nailed it! :smile:
