Circuits, what am I doing wrong
  • Thread starter Thread starter kliker
    Circuits
The discussion revolves around calculating the maximum power consumption of a circuit with resistors rated for 24W. The initial calculation incorrectly assumed the total power could be derived from the power of individual resistors without considering their configuration. The correct approach involves recognizing that the maximum power for each resistor must be respected, leading to a total maximum power of 36W for the circuit. The user acknowledges the correction and understands the proper method for calculating power in the circuit. This highlights the importance of understanding resistor configurations and power limits in circuit analysis.
kliker
[PLAIN]http://img258.imageshack.us/img258/9067/39943009.png
given this circuit if each of the resistors may consume maximum power = 24 W without overheating, find the maximum power that the circuit can consume
P = I*V
V=I*R
ok the first two are in parallel, so i found the resistance of both, which is 3/2, then we have two resistors in series and I found the total resistance which is 3/2 + 3 = 9/2
before doing this i found the I(total)
which is P = I*V => 24 = I^2*3 => I = +/- 4
having the I total and the total resistance I said
P = I^2*R = 16*9/2 = 72 W
but the book says 36, what am I doing wrong?
Thanks
You are wrong with your first statement. You said that the max. power consumption of a SINGLE resistor is 24W, but calculated a power consumption of a whole circuit.
My idea is as it follows:
1. P=I^2*R. Obviously the currency flowing through the resistor on the right will be the, khem, biggest (dunno what's the proper word in english :P). You should assume that it is 24W. It allows you to calculate the currency, and then everything else. Checked, gives 36W.
E: Due to the rules of the board I've deleted the exact solution :).
thanks irycio I understand it now
