Circular motion and tension problem
The discussion revolves around solving a physics problem involving circular motion and tension in a pendulum. An 8.700 kg mass is suspended from a 1.490 m string and revolves horizontally at a speed of 3.755 m/s, with the goal of finding the angle between the string and the vertical. Participants suggest breaking down the tension into horizontal and vertical components and applying Newton's second law to derive equations for tension in terms of the angle theta. By resolving forces and equating the expressions for tension, a quadratic equation can be formed to solve for theta. Ultimately, the correct angle is determined to be 51.1 degrees, confirming the calculations.
VenomHowell15
http://capaserv.physics.mun.ca/msuphysicslib/Graphics/Gtype11/prob03_pendulum.gif
A mass of 8.700 kg is suspended from a 1.490 m long string. It revolves in a horizontal circle.
The tangential speed of the mass is 3.755 m/s. Calculate the angle between the string and the vertical (in degrees).
There's the question I'm given. I cannot get terribly far with this one, despite being able to ace all the other questions on the assignment... Nonetheless, that is moot.
There are 3 unknowns here for this problem... Fortunately, one of the unknowns can be written in terms of the other one. The radius of the lower circle can be written as (r)(sin(theta)) which is in turn (1.490)(sin(theta)). I believe tension can be written as T=mg/(cos(theta)), but I'm not entirely sure.
I've attempted to do (mv^2)/(r(sin(theta)) = (mg)/(cos(theta)) and work it through to get ((v^2)/(gr)) = (tan(theta)), but it's not giving me the correct answer.
I'm kind of stuck, not sure where I'm going wrong with this.
Split the tension of the rope into horizontal and vertical components and then apply the second law in both directions.
Did you get there yet? What is the answer? I tried it by eliminating all but theta and if I'm right, I'll give you some clues.
Tx = (mv^2)/(sin(theta)r) and Ty=(mg)/(cos(theta))
I can do that, sure, Neutrino. Just not sure what else to do with it from there. I have neither tension, theta, or the radius of the conical base. Only the length of the string, the mass, and the velocity.
So eliminate all but one variable ...
by resolving vertically you can get T in terms of theta and you already have R in terms of theta, so you now have just one variable.
You say your answer isn't correct. What is the correct answer?
I keep getting 44.0 degrees, but I think I know what I'm doing wrong, so I'll get back to you on that after playing around with the formula some more.
If you know what the correct answer is I might be able to give you some clues.
I have an answer, but would like to know it's correct before leading you up the garden path.
Me too, me too! :biggrin: :-p
GO on radou, what did you get? 51.1?
Umm...nope. :smile: I'd rather not get involved. :biggrin:
oh well, bedtime.
rsk said:
oh well, bedtime.
Last off-topic post: well, it sure is long past bedtime where I'm from. :smile:
According to the computer, that's the answer I should be getting... So, yes, 51.1 is the correct answer. I'm just not quite able to get that.
I'm betting I'm just running into one little snag in the process that's messing it up.
The problem is that one of these equations is not correct. Draw the FBD with the tension and gravity acting. Resolve the tension into components, and be careful about what you are equating. The mass is moving horizontally in a circular path, so the horizontal component of the net force is the centripetal force. The net vertical force is zero.
OK venom. If it's not too late here's what I did. If is IS too alte - sorry - but I did offer this hours and hours ago!
First I resolved vertically. That gives you an expression for T in terms of theta - in terms of cos(theta) to be precise - which I think you already wrote somewhere earlier.
Then I resolved horizontally. You put R = Lsin theta (L = total length) and this gives you an expression for T in terms of theta - but it's got a sin^2(theta) in it.
You now have two expressions for T - one in terms of cos(theta) and one in terms of sin^2(theta)
Equate them, and remember that sin^2(theta) = 1 - cos^2(theta)
Now you have a quadratic equation where cos(theta) is the variable
Solve it and you can find theta.
Ah-ha! Perfect! Thanks guys. That really helped me out!
