Circular Motion of a Marble: What Determines the Speed at a Given String Length?
The discussion revolves around a marble being swung in a horizontal circle at the end of a string, with a specific angle given. Participants are exploring the relationship between the string length, the forces acting on the marble, and the speed of the marble.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the forces acting on the marble, including tension and gravity, and their resultant effects. There is an emphasis on understanding the role of these forces in providing the necessary centripetal force for circular motion.
Some participants have suggested drawing a free body diagram to clarify the forces involved. There is an ongoing exploration of how the tension's components relate to the centripetal force and the angle of the string, but no consensus has been reached on the specific calculations or relationships.
Participants note the absence of mass and the number of revolutions as constraints in solving for the speed of the marble, which adds to the complexity of the problem.
klc2006
You swing a marble with mass m attached to the end of a string in a horizontal circle as shown in the figure below. The angle that the string makes with the vertical is
θ = 37°.
(a) Find the speed of the marble when the string is 26.0 cm long.
soh,cah,toa
Ar = v^2/r
4ii^2r/T
I solved for the radius by using trig, but now I don't know what to do. Without mass or revloutions, I don't know how to solve form the speed.
Draw the free body diagram: What forces act on the marble? What is the resultant when the marble moves along a horizontal circle? You do not need the value of the mass: it will cancel.
ehild
You have gravity and force of tension
Yes, and what is their resultant?
ehild
I actually have no idea. I'm blanking out.
if its moving in circle, then some force should be providing centripetal force. Here that force is horizontal component of tension. And since the ball isn't moving up or down, force of gravity should be balanced by some other force, namely vertical component of tension.
just as ehild said, making free body diagram would make it more clear.
The resultant of the tension and gravity is equal to the (horizontal) centripetal force. How is it related to mg and the angle of the string with the vertical ?
ehild
