Circular ring in xy-plane with current, find current density
jajay504
Consider a circular ring of wire of radius a that resides in the x-y plane through the origin. The center of the ring coincides with the origin and you can regard the thickness of the wire to be infinitesimal.
a. Given that a current I flows in the ring, find an expression for the current density J.
∫B(r).dl = μ∫J(r).da
ok, I know J(r)=Io * δ(x)*δ(y) z
How do I get this in cylindrical coordinates (ρ,θ,z)?
Well, the current density is only non-zero at z = 0, that corresponds to it being non-zero only at θ = π / 2, or cos(θ) = 0. So you should have a delta function for that. Additionally, it's non-zero only at ρ = R, so you should have a delta function for that as well. If I remember Jackson correctly, you'll also need a normalization factor of 1/R because θ (and therefore the first delta function) is a dimensionless quantity, so you divide by 1/R to maintain the proper units for current density of current / area (I'm not really sure why this works, I just took Jackson at his word on this one). The original delta functions are functions of position coordinates and therefore already have 1/L dependence.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
