Classical Ideal Gas: Pathria's Insight on Non-Interacting Particles
rbwang1225
In the book of Pathria(p.16), he mentioned that If (i) the mutual interactions among particles are negligible and (ii) the wave packets of individual particles do not significantly overlap, then there does not exist any spatial correlations among the particles in the system composed of non-interacting particles.
I don't really understand the second statement.
Can anyone interpret it more clearly? Thanks in advance.
I could be wrong but I think it is a fancy way of saying that the particles do not have a moment of inertia. This would mean that the particles cannot acquire internal energy. Perhaps others will comment.
AM
No, the second statement means that the gas is not degenerate so that you have to apply quantum statistics and the classical statistics works well.
In my own point of view, I think the 2nd statement is saying that the probability of finding the particles at the same place is small, which is to say the wavefunctions do not overlap significantly. But I am not sure, can anybody comment on it more clearly?
Wave functions overlapping does not necessarily mean that they are at the same position. Consider plane waves. They would overlap if their wave vectors have approximately equal values, which would mean that their momenta are approximately the same. But, a plane wave is extended throughout the whole volume, so you cannot say the particles are nearby.
You should not ascribe too much weight to their 'condition'. It simply comes from the math. Namely, consider Fermi-Dirac or Bose-Einstein distribution:
[tex] \overline{n}_{i} = \frac{1}{\exp\left(\frac{\varepsilon_{i} - \mu}{T}\right) \pm 1}[/tex]
They would both reduce to the Maxwell-Boltzmann distribution:
[tex] \overline{n}_{i} = \exp\left(\frac{\mu - \varepsilon_{i}}{T}\right)[/tex]
when:
[tex] \exp\left(\frac{\varepsilon_{i} - \mu}{T}\right) \gg 1[/tex]
The left hand side is a monotonically increasing function of energy. So, it has a lower bound for the lowest possible energy of the particles. We may take this to be zero. Then, we still have to satisfy the condition:
[tex] \exp\left(-\frac{\mu}{T}\right) \gg 1 \Leftrightarrow \exp\left(\frac{\mu}{T}\right) \ll 1[/tex]
The chemical potential needs to be negative and equal several times the temperature by magnitude for this inequality to be satisfied (because of the exponential). The chemical potential is fixed essentially by the density of particles. Let us evaluate it for a free ideal gas under the Maxwell-Boltzmann distribution: Then, the plane waves are energy eigenstates:
[tex] N = \sum_{i}{\overline{n}_{i}} = \sum_{\mathbf{k}}{\exp\left(\frac{\mu - \varepsilon_{k}}{T}\right)}[/tex]
[tex] N = \exp\left(\frac{\mu}{T}\right) \, \sum_{\mathbf{k}}{\exp\left(-\frac{\hbar^{2} k^{2}}{2 m T}\right)}[/tex]
Going over from summation to integration with respect to [itex]\mathbf{k}[/itex] according to the well-known rule:
[tex] \sum_{\mathbf{k}}{f_{\mathbf{k}}} = V \, \int{\frac{d^{3} k}{(2\pi)^{3}} f(\mathbf{k})}[/tex]
we get:
[tex] N = V \, \exp\left(\frac{\mu}{T}\right) \, \frac{4\pi}{(2\pi)^{3}} \, \int_{0}^{\infty}{k^{2} \, \exp\left(-\frac{\hbar^{2} k^{2}}{2 m T}\right) \, dk}[/tex]
The integral can be made dimensionless by introducing:
[tex] x \equiv \frac{\hbar^{2} k^{2}}{2 m T} \Rightarrow k = \frac{(2 m T x)^{\frac{1}{2}}}{\hbar}, \; dx = \frac{(2 m T)^{\frac{1}{2}} \, x^{-\frac{1}{2}}}{2 \hbar} \. dx[/tex]
[tex] N = V \, \exp\left(\frac{\mu}{T}\right) \, \frac{1}{2\pi^{2}} \, \frac{(2 m T)^{\frac{3}{2}}}{2 \hbar^{3}} \, \int_{0}^{\infty}{x^{\frac{1}{2}} \, e^{-x} \, dx}[/tex]
The value of the integral is [itex]\Gamma(\frac{3}{2}) = \pi^{1/2}/2[/tex] and we can identify [itex]n \equiv N/V[/itex]. Then, we get for the chemical potential:<br /> <br /> [tex] \exp\left(\frac{\mu}{T}\right) = n \, \left(\frac{2 \pi \hbar^{2}}{m T}\right)^{\frac{3}{2}} \ll 1[/tex]<br /> <br /> We identify:<br /> <br /> [tex] \lambda_{T} = \left(\frac{2 \pi \hbar^{2}}{m T}\right)^{\frac{1}{2}} = \frac{h}{\sqrt{2 \pi m T}}[/tex]<br /> <br /> as the <i>thermal De Broglie wavelength</i> and [itex]r = n^{-1/3}[/tex] as the average interparticle distance. Then, the above condition can be written as:<br /> <br /> [tex] \exp\left(\frac{\mu}{T}\right) = \left(\frac{\lambda_{T}}{r}\right)^{3} \ll 1 \Leftrightarrow \lambda_{T} \ll r[/tex]<br /> <br /> , i.e. we can use classical statistics (the gas is non-degenerate) if the thermal De Broglie wavelength is much smaller than the average inter particle distance. I guess this is why they interpret it as their wavefunctions (whose wavelengths are of the order of [itex]\lambda_{T}[/itex]) should not 'overlap'.[/itex][/itex]
