Classical Mechanics - finding displacement with given force
In summary, the problem involves finding the displacement of a particle with a mass of 3kg, starting at x = 1m and v = 0 m/s, at time t = 5s. The force equation is F = (v/9)(3 - x^2), and the homework equations of F = m(dv/dt) or F = m(dv/dx)(v) are relevant. The attempted solution involves using integrals to find x, but the correct approach is to use implicit equations and integrate the x terms with respect to x.
c_pearls
- The force acting on a particle m = 3kg is given by the following force equation: F = (v/9)(3 - x2),
the particle begins at a position of x = 1m with a speed of v = 0 m/s at time t = 0s. Find the displacement of the particle at time t = 5 s.
F = m(dv/dt) or F= m(dv/dx)(v)
Our professor set up the problem wrong, so he said all we have to do is get to the integral where we'd find x and stop.
Welcome to PF;
... so what did you do?
Simon Bridge said:
Welcome to PF;
Well I tried it two ways, neither of which I thought was right...
n=7vks70HEUV82ikRKq9lDD9E1%2b0Mw0NDmL%2ftM1%2fH%2b4p0%3d&docid=016fc1db036ef4106b07348020be72487.jpg
token=YcoBfb2774deTF3wZ6MaQrYbVQ%2fvPYwJAM%2faX8w795U%3d&docid=0155b644af83a49af8eeec1a8acd84697.jpg
In the first page, you cannot take the x's outside the integral over t because x is a function of time.
On the second page, you, instead, tried changing the variable ... that seems reasonable to me.
You'll end up with an implicit equation for x(t) but you only need x at a particular time.
So on the 2nd page you would end up with -(1/3)x3t + 3xt - (8/3)t ?
No - remember, the x terms are not constants in time.
You have to integrate the x terms wrt x.
What is classical mechanics?
Classical mechanics is a branch of physics that studies the motion of objects under the influence of forces.
What is displacement?
Displacement is the shortest straight-line distance between the initial and final positions of an object.
How do you find displacement with a given force?
To find displacement with a given force, you can use the equation d = F/m, where d is displacement, F is force, and m is mass.
Can displacement be negative?
Yes, displacement can be negative if the initial position of the object is greater than the final position.
What is the unit of displacement?
The unit of displacement is usually meters (m) in the International System of Units (SI).
