Classicality in Bell's original reasoning
  • Level: Undergrad
  • Thread starter A. Neumaier
    bell's theorem
105 replies · 12K views · last reply
zonde said:
Bell's analysis does not cover theories that give only statistical predictions.
That's incorrect. The Bell paper absolutely considers such theories. The requirement is that there be some function or set of functions that would determine an outcome, based on some set of input parameters. You don't need to be able to actually predict each outcome. So lack of knowledge could lead to statistical predictions in such cases.
zonde said:
There are some unscientific ones. Superdeterministic and maybe interpretation where measurement results can't be considered as physical facts.
I am disappointed, aren't we supposed to talk about science here ?o_O
rubi said:
Griffiths has proved that QM is compatible with locality
As a layman I suppose it would be impossible for me to get a tone down version of that proof (or a free reading at least ?)
I found this article but it doesn't sound right. I am quite disturb by the apparent confusion between FTL "influence" and its opposite : non-local/instantaneous.
I also have always taken for granted that when a particle with an entangled property is measured, the corresponding entanglement is destroyed by the measurement.. am I correct ?
In most cases, I would say you are correct. There are a few complicating issues: 1) When does the entanglement end (when both are measured or just one) ? 2) The entanglement does not end if entanglement swapping is made to occur.
Consistent histories is an example of a quantum theory, which is local according to the EPR definition. It's often considered to be the modern version of the Copenhagen interpretation.
Griffiths essentially proves that the probability for a non-local influence is ##0##. The argument is too long for me to type it here. Maybe you can get hold of Griffiths book "Consistent Quantum Theory" or maybe he has some version of the argument on the arXiv.
This is Griffiths response to it.
This is the naive view, which is good enough for practical purposes. If you take QM seriously, you would instead expect the particle will become entangled with the measurement apparatus und the environment, i.e. the entanglement is still there, but you cannot see it in the reduced picture.
I would say it make no difference, because the other particle is the only one connected with that property thus future correlation became irrelevant (maybe not for 3 particle entanglement, if it exists, and should be testable).
Thank you, for pointing that out, I had to look it up !
Am I right to understand that as 0% FTL signaling, and 100% instantaneous correlation (which is on what my little code is based on) ?
]This is Griffiths response to it.
My next read, thanks !
I deduce that from the fact that no signaling is possible. So it seems logical that measurement apparatus must somewhat erase the "link" between the particles (or add so much other state to the point of making it random).
If a "delicate" measurement (not forbidding the possibility to redo the same measurement on the same particle) was possible, it would be straightforward to communicate between Alice and Bob
There's this guy who in one page derives bell inequality starting only from the assumption of non-locality (being in two different places at the same time). Anyone wants to see it ?
No. But its one page with 7 equations ... I don't know if there's anything to his arguments, by the way.
Then I can't propose you anything. :wink:
And Stapp's article already contains response to Griffiths response and Griffiths response contains response to response which basically says that: "The reader will have to judge".
rubi said:
Read his paper. He explains that his definition of locality derived from the assumption of CFD.
Can't read this article as it is behind paywall.
But when I look at his definition of "local" from this article http://dx.doi.org/10.1103/PhysRevA.47.R747 it seems that he very carefully avoids any counterfactual reasoning (btw reference [10] is the paper you gave):
"For a given theory, we consider all the possible sequences of N events that can occur in each setup. N is the same for the four setups and arbitrarily large. As in [9] and [10], a theory is defined as being "local" if it predicts that, among these possible sequences of events, one can find four sequences (one for each setup) satisfying the following conditions:
(i) The fate of photon a is independent of the value of β, i.e., is the same in an event of the sequence corresponding to setup (α1,β1) as in the event with the same event number k for (α1,β2); also same fate for a in (α2,β1) and (α2,β2); this is true for all k's for these carefully selected sequences.
(ii) The fate of photon b is independent of the value of α, i.e., is the same in an event k of the sequences (α1,β1) and (α2,β1); also same fate for b in (α1,β2) and (α2,β2).
(iii) Among all sets of four sequences that one has been able to find with conditions (i) and (ii) satisfied, there are some for which all averages and correlations differ from the expectation values predicted by the theory by less than, let us say, ten standard deviations."
rubi said:
zonde said:
But does this contextuality index describe global measurement arrangement as well? As I understand it does.
You understand wrong. In general, it doesn't refer to measurement arrangements at all. The KS theorem just tells us that there can't be a one-to-one mapping.
I found one Griffiths article where he tries to argue that QM is non-contextual Quantum Measurements Are Noncontextual
"The hidden variables approach seems almost inevitably to lead to the conclusion that quantum mechanics is infested with nonlocal influences, and the choice of a measurement at some spacelike separated point can influence what is going on here, a “contextual” influence."
Well, it seems that my understanding of common terminology (KS definition of term "contextual") is correct and you are using some private and rather uncommon terminology.
There is 0% action at a distance, independent of whether you can use it for signaling or not. I don't know what you mean by instantaneous correlation.
He refers to [10], precisely because he has introduced the his notion of locality and explained it in that article. And he clearly explains that it implicitely assumes counterfactual definiteness. I don't know how you get the idea that he "carefully avoids counterfactual reasoning", but you are definitely in disagreement with the author.
It seems that you still didn't bother to understand the KS theorem. Griffiths is not talking about the KS theorem here. The KS theorem says nothing about the meaning of the ##\chi## index. It just says that a one-to-one mapping of observables to random variables is not possible. There are infinitely many ways to write down such a many-to-one correspondence. Making ##\chi## depend on non-local information is a possibility, but not a necessity. The KS theorem does not make statements about locality. Also, as I told you, it is completely irrelevant. The point is that Bell excludes contextual theories from his analysis (or do you see any contextuality index in his proof?)
Well, then please quote his particular point.
I got the idea by very carefully reading his definition and doing some analysis afterwards. And please provide relevant quote from the author if you think I disagree with him.
Wrong. I just do not jump at conclusions about things I'm not sure I understand.
This is first sentence from this paper:
"John Bell in Sec. 5 of [1] while discussing hidden variables in quantum mechanics raised the question of whether quantum theory is “contextual.”"
Reference [1] contains Bell's version of (B)KS theorem.
Eberhard said:
Another justification of this property 3 relies on a concept which was called
(( contrafactual definiteness ~> (-m), a concept used in daily life whenever we
must make a choice. Contrafactual definiteness means that, in a given situation,
the consequence of each of the possible courses of action can be considered
even though the only sequence of events that can be known for certain is the
one produced by the tinal single choice. Thut is we can hypothesize about the
event sequences following the courses of action that will not be chosen.
(Property 3 is the locality definition from your paper)
Your method of carefully reading and doing some analysis doesn't seem to work very well.
As I explained, it is totally irrelevant anyway.
So what? QM is contextual. That's what the KS theorem says. However, it doesn't force any specific form of contextuality. It just says that the mapping must be many-to-one and nothing more.
Thanks. Now I understand where CFD comes into Eberhards definition of "local". It's when he refers to concept of "theory".
Hmm, so do you suggest that we should consider explanations that are not "theories"? Here ... on science forum? :eek:
That's a way better way to put it. And action at a distance means for me impossible (FTL) transfer of momentum/energy (as per SR)
I mean the prediction of QM and how they have been verified experimentally.
That is: NO action at a distance (that means Einstein after all was right) but factual instantaneous correlation (when experimenter coerce the measurement timing of A & B to be as close to identical as possible in the labs-frame)
I take also for granted that instantaneous is not to be confused with "very fast", because instantaneous has no unit of speed (and even less an infinite one), does not concern movement nor any kind of space-time related quantity.
But when other type of quantities (not space-time related, like up/down spin information) "are" observed to change simultaneously ("are" because of to separate observation, not because of two separate quantities), the only logical conclusion is that there is only one of this quantity all along (non-locality/nowhere and everywhere).
I have of course anticipated an absurd response, but I couldn't imagine that it would be that absurd. What did you think? Of course, we are talking about theories. Bell's theorem is talking about theories; Eberhard is talking about theories.
The point is the following: Contrary to what you claimed, Eberhard admits that his definition of locality includes CFD, so his derivation of Bell's inequality and Bell-type inequalities does not make less assumptions than anyone elses derivations.
Now you explain the term "instantaneous correlation" by putting the word "factual" in front of it. Anyway, nothing is instantaneous about quantum correlations.
First, Eberhard's derivation is different as he does not use hidden variables.
Second, all his requirements can be realized in single chronological sequence of events with no parallel counterfactual sequences. So the only sense in which he is using CFD is that he requires that theory makes predictions. That's all.
Ok, once again:
Eberhard's locality definition requires that the theory makes predictions about unperformed measurements. If a theory does not make such predictions, for instance, because it is contextual, then Eberhard's locality definition doesn't apply. The situation is identical to ordinary derivations of Bell's inequality. If you had read paper [10], you would see that his locality definition is just Bell's usual definition with the additional possibility for experimental noise. If a theory violates CFD, then it needn't be local, as usual.
From dictionary:
prediction - a statement made about the future
All future measurements are not (yet) performed. So any theory that makes predictions is making counterfactual statement.
Is it so hard to understand?
zonde said:
From dictionary:
<Mentor's note: edited for distraction>
What is meant is that the theory needs to be able to assign values to quantities that can't be measured simultaneously, like spin along different directions. Eberhard requires this, but it is not satisfied by QM. Hence, QM is compatible with locality.
Sorry, sloppy language again. "Experimental/observed" is what I meant.
I feel like I am back to square one now. Do you meant that QM predict some minimal delay before Bob and Alice can make they observation about an entangled pair state ? I always though they can do them whenever they want to.
Can you point me to this non-instantaneous computation, for example in the case of spin entangled electrons, and eventually the experimental testing of that prediction ?
Time is not a factor (variable) in this case, so it is meaningless to discuss delays, instantaneous, etc. Do you recall my comment (post #64) about "when" and entanglement? That is the point I was making. There is no "when" in the normal sense of the term.
I can tell you that 2 particles were not entangled before time T1 (when we first set things up), and they were not entangled after time T2 (after everything to observe was observed). But I cannot tell you specifically when the entanglement began or when it ended outside of that, nor what is occurring in between. Keep in mind that entangled particles do not need to have even interacted to be entangled, so that complicates things further.
Regardless of all that, QM makes good predictions as to what will be observed.
But isn't quantum contextuality used when trying to understand QM deterministically?(at least that is what Wiki says:"Quantum Contextuality means that in any theory that attempts to explain quantum mechanics deterministically..."
Could you clarify why would anyone insist on explaining QM deterministically, if that's what you are doing? I thought that was precisely what Bohmian mechanics pursued, is the only basic difference between BM and CH the disagreement about locality?
No, it has nothing to do with determinism. The question is whether one can model the quantum observables one-to-one as random variables on a classical probability space. If that is not possible, then the theory is called contextual. Of course, using classical probabilities has nothing to do with determinism. I can also write down a classical probability distribution for a coin tossing experiment (##p_i=\frac 1 2##), but of course that doesn't imply that the experiment is deterministic.
CH has nothing to do with BM. BM is a hidden variables theory, while CH is just standard QM. Everything works exactly like in Copenhagen.
But I totally agree, and I would be very happy not to use "instantaneous", in favor of "non-locality". But that is the term I see everywhere to describe that entanglement (perfect correlation) is, with no evolution with respect to time (and space) (between t1 and t2). I have always understood Bell's theorem as being a way to prove that hypothesis (by observation).
The problem I have is to understand rubi, which seems to say that Bell's theorem is about something else, and that QM can explain (global?) entanglement using locality (thus evolution with respect to space-time). Has Griffith proved that ? In one of its paper he starts to say:
Griffiths said:
The opinion is widespread that quantum mechanics is nonlocal in the sense that it implies the existence of long-range influences which act instantaneously over long distances, in apparent contradiction to special relativity
How can "nonlocal" means "long-range influences which act instantaneously over long distances", when non-local means no space-like nor time-like characteristic. How something with no-size be long, or something with no evolution in time be anything but instantaneous ?
A few sentences below he writes
Griffiths said:
The widespread belief in the existence of such nonlocal effects seems a bit surprising in view of theorems [36, 37], whose validity does not seem to be in doubt, to the effect that these (supposed) quantum nonlocal influences cannot be used to transmit signals or information
It cannot if the entanglement broke at first interaction. It can otherwise.
Griffiths said:
Thus they are not detectable by any ordinary experimental test.
Isn't it trivial to measure by ordinary test (after A and B get back together), that the correlation was indeed non-local ?
How could anyone could "suspect any conflict between quantum theory and special relativity", when non-locality is explicitly defined as not to contradict SR ?
You are not following the argument in its entirety. Rubi/Neumaier/Griffiths line is as follows (and I am referring to comments in concurrent threads as I do this): Bell excludes local realistic (non-contextual) theories; and QM is contextual. So a successful theory need not be non-local.
Yes, it is ALSO true as follows: There does "appear" to be something non-local going on. I want to stress appear. You can't say A causes B, B causes A, or A and B are mutual causes/effects (where A and B are non-local to each other).
So when you "prove" there is something non-local occurring, you really aren't. You have a context which is in fact traced out by a light cone (or cones). The extent of the "non-locality" is the distance between points on a light cone and no further. QM fully qualifies as a local contextual theory, which matches what some of the theorems that Griffiths refers to would indicate.
