Closed curve and orthogonal curvilinear coordinate system
9 replies · 6K views
traianus
Hello, I have a "simple" problem for you guys. I am not expert in math and so try to be simple.
I explain the problem by starting with one example. The polar coordinate system has the following main property: with two parameters, rho and theta, each point is described as the intersection of a circle and a straight line. These two curves are orthogonal and so the curvilinear coordinate system is orthogonal.
Another example is if we use ellipses and hyperbolas: they are orthogonal. The transformation is simple:
x = c*cosh(a)* cos(b) (1)
y = c*sinh(a) * sin(b) (2)
where a>0, and 0<=b<=2pi
Now my question. Suppose that we like to use a set of curvilinear coordinate system (plane x-y only) which is orthogonal. Suppose that instead of ellipses or circles one of the type of curves is a closed path defined by (for example) the equation
x^8/A^8 + y^8/B^8 = 1
which is closed curve similar to an ellipse. Ho do I find a similar trasnformation (like equations (1) and (2)) with the property that the curvilinear coordinate system is also orthogonal? Please help me!
Did you mean the family of curves (parametrized by k > 0)
x^8/A^8 + y^8/B^8 = k
where A and B are fixed constants?
In the obvious way! :smile: Just look at what you want: you want functions of two variables a and b such that:
(1) The derivative WRT a is parallel to x^8/A^8 + y^8/B^8 = k
(2) The derivative WRT b is perpendicular to x^8/A^8 + y^8/B^8 = k
So you should be able to set up a system of partial differential equations. I guess it might not be very easy to solve, though.
Thank you. Can you show the system of partial differential equations that solves the problem? Actually in my case I like to have the coordinate system of the "hyper-ellipse"
x^(2n)/A^(2n) + y^(2n)/B^(2n) = k
where n is a positive integer.
If C(k) is the loop defined by:
x^8 / A^8 + y^8 / B^8 = k
and (p, q) is a point on C(k)
then can you find a tangent vector to C(k) at (p, q)? What about a vector perpendicular to C(k) at (p, q)?
It is an implicit function. So I think that the tangent has equation
7*p^7/A^8*(x-p) + 7*q^7/B^8*(y-q) = 0 (1)
from (1) it follows that the vector perpendicular to the curve is
Vperp= q^7/B^8 * i - p^7/A^8*j (2)
where i,j are the unit vectors. The vector parallel to the curve is then
Vpar = p^7/A^8*i+ q^7/B^8*j (3)
Let me see if I get your point. Curvilinear coordinates means that there is a transformation of the type
x = f(a,b) (4)
y = g(a,b) (5)
Now I have to obtain the system. Please correct if am wrong. If I am not, can you write the system of equations?
Your work is off. I think you just switched which is perpendicular and which is parallel.
You're right that it's an implicit equation: when you differentiate, you should get:
[tex] \frac{8 p^7}{A^8} \, dx + \frac{8 q^7}{B^8} \, dy = 0[/tex]
is the equation for motion along your loop at the point (p, q).
x = f(a,b) (4)
y = g(a,b) (5)
Yep.
Since you wanted one of your parameters to go around the loop, that means when you partially differentiate, the result should be the tangent vector! i.e.
[itex]\frac{\partial}{\partial a} \langle f(a, b), g(a, b) \rangle[/itex] = the tangent vector at <f(a, b), g(a, b)>
and a similar condition for the other direction!
Finding "orthogonal trajectories" used to be a standard problem in ordinary d.e.s. If a family of curves is given by f(x,y)= c, then
[tex]\frac{\partial f}{\partial x}+ \frac{\partial f}{\partial y}y'= 0[/tex]
so
[tex]y'= -\frac{\frac\partial f}{\partial x}}{\frac{\partial f}{\partial y}}[/tex]
The "orthogonal trajectories" must satisfy the differential equation
[tex]y'= \frac{\frac{\partial f}{\partial y}}{\frac{\partial f}{\partial x}}[/tex]
In the case that [tex]\frac{x^{2n}}{A^{2n}}+ \frac{y^{2n}}{B^{2n}}= k[/tex] (you still haven't answered the question as to whether A and B are fixed constants while k determines the member of the family- actually, I suspect that there are some relations between A, B, k), assuming that A, B are constant while k varies over the family, the orthogonal trajectories satisfy
[tex]y'= \frac{A^{2n}}{B^{2n}}\frac{y^{2n-1}}{x^{2n-1}}[/tex]
Thank you for you answers. A, B are constant, as n. So, what is the parameteric representation
y = f(a,b)
x = g(a,b)
in which when a = constant I have the curve
and when b = constant I have a family of curves orthogonal to it (like it happens for polar coordinates in which the lines are perpendicular to the circles)?
A and B must be positive. If I move from a curve fto another one, A and B can change, but they can be function ONLY of the parameter a. Also, they have to be positive.
