The discussion centers on the challenge of matching the output of a CMOS IC, which has a high output impedance, to a 50 Ohm microstrip transmission line. Participants explore various methods and considerations for achieving this impedance matching, including the implications of frequency and the characteristics of the CMOS output.
- Technical explanation
- Debate/contested
- Mathematical reasoning
- Some participants note that the output impedance of the CMOS IC is about 15 megaohms, which presents a significant challenge for matching to a 50 Ohm line.
- Others argue that the output impedance can vary based on the specific IC and its configuration, suggesting that a bipolar pair might be used for better matching.
- One participant raises the question of whether microstrip matching is necessary at the operating frequency of 2 Gb/s, indicating that this could influence the design approach.
- Several participants suggest using a series resistor to help with impedance matching, with one noting that a shunt resistor may also be needed to define the line driving impedance.
- Concerns are expressed about the potential for exceeding the ratings of the CMOS device when driving a low impedance load, emphasizing the need for careful consideration of the overall loss in the system.
- Participants discuss the possibility of using an attenuator at the receiving end to prevent reflections, while also considering the implications of the series resistor on device safety.
- There is uncertainty regarding the specific CMOS logic gate being used, with one participant indicating a lack of information about the internal gates of the IC.
Participants express differing views on the output impedance of the CMOS IC and the necessity of microstrip matching at the given frequency. There is no consensus on the best approach to achieve impedance matching, with multiple competing ideas presented.
Participants mention that the output impedance of the CMOS IC may not be well defined and that the configuration of the MOSFETs can affect the output characteristics. The discussion also highlights the potential for loss due to the proposed impedance matching methods.
Engineers and designers working on high-speed signal transmission, particularly those dealing with CMOS technology and microstrip line applications, may find this discussion relevant.
