Coefficient of restitution of a ball question
The coefficient of restitution (COR) of a ball is independent of the drop height because it primarily depends on the material properties and deformation characteristics during impact. As the ball falls from greater heights, it eventually reaches terminal velocity, leading to a constant collision speed that does not affect the COR. The COR is an approximation that holds true within certain deformation limits, where elastic and inelastic behaviors can be observed. Therefore, regardless of the height, the COR remains consistent as long as the material properties and impact conditions are unchanged. Understanding these principles clarifies why the COR is not influenced by the height from which the ball is dropped.
Jeven
Why is the coefficient of restitution of a ball independent of the height it is dropped from?
A mathematical explanation would be best. Thank you.
I suppose is just an approximation, for deformations within some limits.
Besides, for heights larger than some limit, the ball reaches terminal speed in free fall and the collision speed does not change after that.
But some context will help.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
