Which Statements About Moving a Block Are True?
The discussion revolves around the physics of moving a block on a surface with static friction. It examines the conditions under which the minimum force is applied to initiate and maintain the block's movement. Key points include the angle at which force should be applied to minimize effort and the relationship between static friction, mass, and normal force. The participants are encouraged to analyze the problem using vector components and friction equations. The conversation highlights the complexity of determining the correct approach to solve the problem.
sonutulsiani
A block of mass m is resting on a horizontal surface whose coefficient of static friction is μs.
http://bcs.whfreeman.com/WebPub/Physics/tiplerphysics6e_bridge/question_bank_images/fig5-65.png?2439
Which of the following statements (if any) are true?
A. If you want to apply the minimum possible force to move the block, you should apply it with the force pulling upward at an angle θmin = arctan μs.
B. The minimum force necessary to start the block moving is μs mg/ √1 + μs2.
C. Once the block starts moving, if you want to apply the least possible force to keep it moving, you should keep the angle at which you are pulling the same.
There may be more than 1 answer
Fs=μs Fn
No idea.
Hi sonutulsiani! :smile:
Call the normal force N, and the friction force H.
Then do a vector triangle or x and y component equations for a fixed angle θ …
what do you get? :smile:
