Cold & Hot Wind: What's the Difference?
  • Context: High School
  • Thread starter Thread starter Saphsin
    Cold Hot Wind
The discussion revolves around the differences between cold moving air and hot moving air, particularly in the context of fans operating in rooms with differing temperatures. Participants explore the implications of air velocity, temperature, and the effects of convection currents on air movement.
  • Some participants question the assumption that the air from both fans moves at the same velocity, suggesting that the initial temperatures of the air imply different velocities.
  • There is a discussion about convection currents and buoyancy effects in the rooms, which could lead to variations in air density and velocity away from the fans.
  • One participant notes that close to the fans, the air feels distinctly hot or cold, which raises questions about the nature of the air being blown.
  • Another point raised is the distinction between the average velocity of air particles and the overall velocity of the gas, with implications for temperature differences.
  • Some participants argue that the speed of the fans does not significantly affect the temperature of the air, as temperature is more related to the random motion of air molecules.
  • It is mentioned that the random motion of air molecules at room temperature is much greater than the wind speed generated by the fans.
  • There is a suggestion that the kinetic energy imparted by the fans is quickly converted to random kinetic energy, which may need to be considered in the discussion.
Participants express differing views on the relationship between air velocity and temperature, with no consensus reached on the assumptions regarding air movement and temperature effects.
The discussion highlights various assumptions about air movement, temperature definitions, and the effects of fan operation, which remain unresolved.
Saphsin
What's the difference between cold moving air and hot moving air?
For instance, suppose you put two fans, of the same type, each in one room. One room is cold because the walls are covered in ice and one room is hot because due to the effect of heaters. Turn both fans on and the air flow, the pushing of the air particles in one direction, are both blown towards one direction with the same (almost?) velocity.
What makes one moving air hot and the other cold? The moving air are both moving at the same velocity (about) aren't they? Isn't temperature based on how fast the particles are moving.
Science news on Phys.org
Well how do you know that they are moving with the same velocity?
I don't think this assumption is valid since you started with hot air in one room and cold in the other one, so basically they both have different velocity to begin with ..
Hope I can see more replies to this topic from other members ..
That's why I said "about" since the temperature in both room is different, I assumed some changes in the velocity of each blowing air. But generally, in the larger picture, the fans are blowing the air at the same speed. (am I wrong?)
One thing to be considered is the convection currents of the hot/cold rooms. This would produce a buoyancy effect, as there will be fluctuations in the air density across the room and thus you will not necessarily have the same velocity far away from the fan. This is only true if the rooms are open systems (heat can transfer in and out of the room). This is also neglecting the heat contribution of the fan to the room.
On the other hand, you also have to consider the density of the air in a closed system. In this case, the hot air fan will actually have a slightly higher velocity because the air density is lower. This is also assuming the energy output and blade design of each fan are identical.
But close to fan, one blowing air feels hot and the other blowing air feels cold doesn't it?
of course, did you expect to get hot air from a fan blowing cold air ?
Dave
I think there is a difference between the average velocity of the constituent particles, and the velocity of the gas as a whole. The particles are moving about randomly in all directions, even in the wind, but in the wind there is a bias towards the direction of the wind. This bias could be of the same magnitude for both hot and cold winds, but the average particle velocities may not be identical, so they have different temperatures.
Are there no definite answers?
Answers to what? I see a lot of answers.
I'm not entirely clear on your question, but I'm thinking what you need is in post #7. Are you thinking that since temperature is a measure of kinetic energy that if you blow air with a fan it should get hotter? Well it actually does, but the speed of the air when blown with a fan is very small compared to its random motion, so the temperature increase is very small.
The speed with which the fans are blowing the air is irrelevant to its temperature. The "heat", and so temperature, of a gas depends upon its random motion. That is the average difference of speed from the overall average speed of the molecules making up the gas. Increasing or decreasing the overall averge speed does not change the random motion of the molecules making up the gas.
To extend the good answers in posts 7, 9 and 10: at room temperature, the random motion of molecules in air is of the order of 400m/s, similar to the speed of sound. The fan can generate wind with something like 1m/s.
True up to a point where theory meets practice: when you blow air with a fan, all of that non-random kinetic energy is quickly converted to random kinetic energy. As pertains to this thread, it therefore must be included.
  • · Replies 66 ·
  • · Replies 35 ·
