Collecting energy from a hot diffuse source
The discussion focuses on collecting energy from a column of hot gas that emits radiation in all directions. The goal is to maximize the energy collected through a window and funnel it into a fiber optic using a coupler with a specific acceptance angle. The application is for doctoral research involving inverse radiation methods to analyze gas properties through spectral measurements. Participants are encouraged to share ideas on effective collimation techniques to optimize energy capture from the diffuse source. The aim is to enhance the efficiency of energy collection for accurate temperature and composition analysis.
edge540t
Alright, let's see what ideas everyone comes up with on this question. I'm no optics guru, so I'm hoping you have better ideas than me. Here's the situation: I have a column of hot gas wherein every gas molecule emits radiation over 4π sr. At one end of the column I have a window where emitted energy can pass through to be collected. The end goal is to collect as much energy as possible from this hot gas column and focus it into a fiber optic. I have a fiber coupler that accepts collimated light and focuses it into the fiber. So, the question becomes what is the best way to collimate as much energy as possible from this diffuse source so it will go into my fiber? The coupler has some acceptance angle θ (it accepts a column + some small divergence.
Welcome to the PF. What is the application? Is this a school project?
This is part of the design for some experiments I need to run as part of my doctoral research. The application is inverse radiation methods. I want to collect radiation, send it to my spectrometer, then use the measured spectrum to deduce the temperature and/or mole fractions of gases in the chamber that emitted the radiation.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
