Collision of a puck and a brick
The discussion revolves around a collision problem involving a puck and a brick, focusing on the conservation of momentum and the resulting equations derived from the collision parameters.
  • Mathematical reasoning, Assumption checking, Problem interpretation
  • Participants explore the relationships between the velocities and angles of the puck and brick post-collision, questioning the validity of certain algebraic manipulations and assumptions made in the calculations.
Some participants have pointed out potential mistakes in the original poster's calculations and suggested starting from the general equations of motion before substituting specific values. There is ongoing examination of the algebraic steps taken, with some participants clarifying the implications of squaring equations.
The discussion includes references to specific values and parameters related to the masses and velocities of the puck and brick, indicating a structured approach to solving the problem while also highlighting potential arithmetic errors.
ac7597
A hockey puck of mass m=0.36 kg slides in the positive X direction at v=13.8 m/s. It collides with a stationary brick of mass M=1.35 kg.
After the collision, each object slides away to the right. The puck slides at a new speed u=10.410 m/s, at an angle of α above the X-axis, while the brick slides at a speed w=1.340 m/s at a different angle β below the X-axis.
This collision is : inelastic
What is the angle α?
momentum=(mass)(velocity)
x(before)y(before)x(after)y(after)
puck (0.36)(13.8)=4.9680(0.36)(10.41)cos(α)(0.36)(10.41)sin(α)
brick00(1.35)(1.34)cos(β)-(1.35)(1.34)sin(β)
total4.968 N*s04.968 N*s0
thus: (0.36)(10.41)sin(α) =(1.35)(1.34)sin(β)
β= sin^(-1)[3.747sin(α)/1.809]= sin^(-1)[2.071sin(α)]
(0.36)(10.41)cos(α) + (1.35)(1.34)cos(β) = 4.968
3.747cos(α) + 1.809cos(sin^(-1)[2.071sin(α)] ) =4.968
3.747cos(α) + 1.809 (1-(2.071sin(α))^(2) )^(1/2) = 4.968
2.071cos(α) + (1-(2.071sin(α))^ (2) )^(1/2) = 2.746
4.29cos^(2)(α) + (1-(2.071sin(α))^(2) ) = 7.54
4.29cos^(2)(α) + 1-4.29sin^2(α) = 7.54
4.29cos^(2)(α) -4.29(1-cos^2(α)) = 6.54
4.29cos^(2)(α) -4.29 + 4.29cos^2(α) = 6.54
8.58cos^(2)(α) = 10.83
α=undefined ?
Here is your mistake. Do you see why this doesn't work?
Suggestion: start with ##m_1,v_1,m_2## and ##v_2## and solve the general problem. Then substitute in the values of the parameters. You are much less likely to make arithmetic errors that way and it makes it easier to understand the equations you are looking at, and possibly avoid errors like the one you have just made.
I squared the equation so [2.071cos(α)]^2 = 4.29cos^2(α) , 2.746^2=7.54 , and [(1-(2.071sin(α))^ (2) )^(1/2)]^2=
But ##(a+b)^2 \ne a^2+b^2##
if 2.071sin(α)=u
and cos(sin^-1(x))= (1-x^2)^(1/2)
then: (1-u^2)^(1/2)
thus:
2.071cos(α) + (1-u^2)^(1/2) = 2.746
4.29cos^(2)(α) + (1-u^2) = 7.54
So you are saying that if ##a+b=c##, then ##a^2+b^2=c^2##.
But given ##1+2=3##
##1^2+2^2=3^2##
##5=9##
So (##a+b=c## implies ##a^2+b^2=c^2##) is not correct. If you square one side of the equation, you have to square the other side, too, like this:
##a+b=c##
##(a+b)^2=c^2##
##a^2+2ab+b^2=c^2##
α=17.8 degrees
thanks
  • · Replies 35 ·
