Colors in white light visible to the naked eye?
  • Context: High School
  • Thread starter Thread starter lnrbm
    Eye Light White light
The discussion revolves around the visibility of colors in white light as perceived by the naked eye. Participants explore the nature of white light, the perception of color, and the mechanisms of human vision, touching on both theoretical and conceptual aspects.
  • Some participants assert that colors must be visible in white light, while others clarify that 'white' light is a mixture of all visible colors.
  • One participant explains that a white object reflects radiation across the visible spectrum, leading to the perception of white when all colors are combined.
  • A later reply questions whether we can perceive all the wavelengths contained in white light with our bare eyes, suggesting that while we see white, we do not see the non-visible wavelengths.
  • Another participant mentions that to see the colors of white light, one could use a glass triangular prism, prompting further inquiry about the necessity of such a tool.
  • Some contributions discuss the role of the brain in interpreting light and color, noting that colors are perceived as a mental construct and that some individuals may experience synesthesia.
  • Participants also touch on the physiological aspects of light perception, including the function of cone receptors in the eye and the influence of light on melatonin production in the body.
Participants express a mix of agreement and disagreement regarding the visibility of colors in white light. While some affirm that white light contains all colors, others question the ability to perceive these colors simultaneously without additional tools. The discussion remains unresolved on several points, particularly regarding the perception of non-visible wavelengths.
Some statements rely on assumptions about human perception and the definitions of color and light. The discussion includes references to physiological processes and individual experiences that may not be universally applicable.
lnrbm
Hello,
Simple question: Should they be visible to the naked eye?
I googled it, but haven`t found any closely related material :)
I`m really interested in this, but have no required knowledge to really answer this question nor explain it properly.
Best Regards
Science news on Phys.org
You couldn't see anything if colors were not visible in 'white' light. I'm taking slight liberties with your question because there is no such thing as 'white' light. You see color because the object you're looking at absorbs the other wavelengths of light that your light source(s) illuminate it by.
If this isn't quite what you meant, try rephrasing the question and we'll have another go at it.
When an object is white, it means that it is reflecting radiation across the spectrum of visible light. White looks so because it is so reflective. If only red light hit the white object, it would look red, if only green light, then green. For some reason, when combined, reflected radiation from the sun, across the visible spectrum is translated by our eyes and brains into what we perceive as white.
Hello,
Ok. You have given me a reasonable answer for my question (which wasn`t precise, as i assumed).
A better version of the question would be: Can we also perceive the colors of all the wavelengths that are contained in the light which we see as white with our bare eyes? :)
Best Regards
Yes. The question is essentially redundant: what we call white is the mixture of all the colors we see.
White light may also contain other wavelengths, but we don't see this. We only see the visible part (of course). Nothing prevents wavelengths outside the visible range to be included in the mix. Whether some is included or not, we see the same white. To see the colours of white light, get a glass triangular prism.
It all comes down to this: Do I really need a glass triangular prism? Can a "...bare eye..." see them?
The eye collects the information, so yes we see them. To make it easy on us, our brain translates the information into what we perceive as white. I think.
You have to realize, that colors, as we perceive them, are nothing more than a mental construct. Some people have anomalous brains, which mix up our senses, and they see colors when they hear sounds, smells, etc.
Maybe someone can chime in and explain how and why we perceive a mix of light of different frequencies as white.
When we use technology in spectrometry, to collect information about a light source, what we collect is raw data identifying the frequencies individually including frequencies that our eyes are incapable of seeing. If we want to make an image out of it, we have to assign colors to frequencies and produce an image we can see. The point is that the color we see, is not as important as what it stands for. Our do the same thing, they assign certain frequencies to colors codes which our brain uses to make sense of what we see. For practical purposes, picking out many frequencies out of a mixture of different frequencies doesn't help us much. There would be no real purpose for that.
On the other hand, you never know what the subconscious knows. Our bodies communicate with itself independent of conscious thought. When light hits us, a signal is sent to the Pineal gland telling us it is day, when we are in the dark, our pineal gland releases melatonin, a hormone which is linked to sleep cycles. Blue light specifically is responsible for halting melatonin production, before bed, if your where goggles which block blue light, your pineal gland can produce melatonin.
"Light dependence
Production of melatonin by the pineal gland is inhibited by light and permitted by darkness. For this reason melatonin has been called "the hormone of darkness". Its onset each evening is called the Dim-Light Melatonin Onset (DLMO). Secretion of melatonin as well as its level in the blood, peaks in the middle of the night, and gradually falls during the second half of the night, with normal variations in timing according to an individual's chronotype.
It is principally blue light, around 480nm, that suppresses melatonin,[30] increasingly with increased light intensity and length of exposure. Until recent history, humans in temperate climates were exposed to few hours of (blue) daylight in the winter; their fires gave predominantly yellow light. Wearing glasses that block blue light in the hours before bedtime may avoid melatonin loss. Kayumov et al. showed that light containing only wavelengths greater than 530 nm does not suppress melatonin in bright-light conditions.[31] Use of blue-blocking goggles the last hours before bedtime has also been advised for people who need to adjust to an earlier bedtime, as melatonin promotes sleepiness."
http://en.wikipedia.org/wiki/Melatonin
You are referring to synesthesia, a condition which I happen to have, but that`s not the reason why I asked the question above btw.
Yes, that would be interesting. I was assuming that the topic would require some physics and maybe biology knowledge?
Anyway, the whole point of the topic was to check if it`s known for one to, while looking at a lamp post light let`s say, see the white AND the all the wavelength colors that are contained in it (in the visible spectrum range of course) at the same time, because I can actually see it as described.
P.S. This is why the thread was in the Scepticism & Debunking forum before it was moved.
Thank you for the info. I will look into it more closely.
The eye has three types of light sensitive cells called cone receptors. Each is sensitive to a different range of wavelengths. Mixtures of light we see as strongly colored stimulate one or two of these more strongly than the others. Light that stimulates all three is seen as white. (an oversimplified explanation, the eye also has rod receptors that aren't strongly color sensitive, and the response of the cones is more complicated, but this suffices)
Your eyes respond to all wavelengths in the visible range, your brain interprets the resulting signals as various colors. It's really not at all clear what you're asking...if this qualifies as "seeing colors in white light", then the answer to your question is "yes": you do see them, you see them as white. If you're seeing white light as having color, then it may be a symptom of a serious problem, and you should probably consult a doctor ASAP.
No, because the point sources for each color are adjacent to each other at a molecular level, but our brain imagery doesn't have this spatial resolution. Use filters to see the colors one at a time.
In other words, if you could separate the colors of white light coming off a blank screen with your eyes, what would define the location of each color? Why should red be "there" and blue be "here"?
Think of pixels on an LCD computer screen, it all comes down to resolution.
cjameshuff said:
It's really not at all clear what you're asking...If you're seeing white light as having color, then it may be a symptom of a serious problem, and you should probably consult a doctor ASAP.
Yes. This is what i was typing about in the previous posts.
Look at a strong light source that radiates white light (like on a lamp post) from medium distance. Try placing something in front of your eye while looking at the light source to block your sight and then lower it gradually and very slowly while watching the 'edges' of the light. Maybe you`ll understand what I was referring to all this time.
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 66 ·
