Combined Loading on an L-shaped beam
  • Context: Engineering
  • Thread starter Thread starter morpheus343
    Mechanics of materials
The discussion revolves around the analysis of combined loading on an L-shaped beam, focusing on determining the axial force (Fy) and bending moment (Fx) at various points. Participants explore the application of stress equations and the implications of loading conditions, including shear and moment diagrams.
  • Homework-related
  • One participant attempts to calculate stresses at points a and b using the relationship σ=εE, noting the presence of unknowns Fy and M in their equations.
  • Another suggests replacing the force F with its effective loading to clarify the analysis and recommends producing shear moment diagrams to identify potential errors.
  • There is uncertainty regarding the lengths of the beams, with some participants questioning whether they are the same length and noting that no measurements are provided.
  • Participants discuss the direction of moments at point B, with conflicting views on whether it should be clockwise or counterclockwise based on the applied forces.
  • One participant expresses confusion about the application of bending stress and normal stress due to the forces acting on the beam, considering multiple cutting points for analysis.
  • There is a suggestion that the internal moment should be expressed as a function of the applied forces and distances, with a participant skeptical about the assumptions regarding the beam's dimensions.
  • Concerns are raised about the number of unknowns in the problem, with one participant feeling that there are too many variables to solve definitively with the available equations.
Participants do not reach a consensus on several aspects, including the correct application of moment directions, the significance of beam lengths, and the overall approach to solving for the unknowns in the problem. Multiple competing views remain throughout the discussion.
Participants note limitations in the problem due to missing measurements and assumptions about beam dimensions. There is also uncertainty regarding the application of sign conventions in the shear and moment diagrams.
Students and practitioners interested in structural analysis, particularly those dealing with combined loading scenarios and beam mechanics, may find this discussion relevant.
morpheus343
Find Fx and Fy.
I tried calculating σα,σb,σc,σd using σ=εE for each point since i know the strains for each point. Then took the section from the top to points a,b. Fx will create a bending moment M and Fy is axial force, so for a: σα=-Fy/A - Mz/Iyy which has 2 uknowns the Fy and M. I do the same for point b: σb=-Fy/A +Mz/Iyy and solve a 2x2 system and find Fy and M. Not sure so far
stress
morpheus343 said:
Homework Statement: Find Fx and Fy.
Relevant Equations: stress
Can you break the diagram into two pictures so the text is larger?
Should be visible now
Ok, go ahead and replace ##F## with its effective loading at the top of the column so we are clear.
Then proceed with finding the reaction forces at the base. It's a good idea to produce shear moment diagrams, as it should help you find an error (I believe) you are making.
I need to add a moment at the top?
I'm assuming they have given the length of the beams?
No
morpheus343 said:
No
:wideeyed:
Are they the same length? Does it say anything about their length?
No measurements given for any of them. It said the strains have been calculated with rosettes, not sure if that matters for the solution or it's just filler talk.
I think it's just to explain how you came to find said strains IMO. let's just call them both length ##L## for now ( I am now certainly unsure of how to get a numerical answer...), but lets continue so you can see the issue with what you were proposing.
I don't know if you go stuck or not, but have you had any luck finding reaction forces and/or producing a shear moment diagrams ( or just using the relevant equations to determine the internal moment ) ?
Furthermore, its preferable that you format your math using LaTeX Guide. It doesn't take long to learn, and it makes the communication process much smoother.
The internal moment at a random length x is M=Mtop+Fx*x ?
You have the right idea, but you are applying things incorrectly. What do you find for the reaction moments, forces at the base of the column. Please draw a diagram turning that portion horizontal.
Also, please follow the link I gave and reply with latex for math. It’s really not a difficult thing to learn. It is certainly not too much to ask given the fact that you are receiving free help.
morpheus343 said:
What direction is the moment at B? And what is its value in terms the assumed beam length ##L##?
counterclockwise?
morpheus343 said:
counterclockwise?
It's the external effect of ##F_y## (applied at distance ##L##) on the beam. Just like the forces. What direction is it?
you mean it should be clockwise to counteract the rotation that Fy creates?
Fx * when perpendicular
No it should be clockwise because it is the rotation ##F_y## creates. We are not looking at an internal force there. We are looking at external forces/loads at ##B##. We are replacing the external loading condition out at the end where ##F## is applied, with an equivalent external loading condition at the column.
These are perfect opportunities to use LaTeX Guide for math formatting. I'm not going to ask again.
I get it now
F_y , not sure why it's not showing correctly in preview i copied your LaTeX code
You don't have it in delimiters that lets it know to execute it as latex code.
Code:
##F_y##
makes inline Latex Code
Like this ##F_y##
If you want an equation centered by itself use:
Code:
$$ F_y $$
Like this:
$$ F_y$$
##F_y## okay thanks
morpheus343 said:
##F_y## okay thanks
Also there is a "glitch" ( side effect of trying to save processing power on the site) where if there is no latex in the thread, then latex will not show up in preview.
morpheus343 said:
I get it now
So are you good on the whole problem, do you see the issue?
Your shear/moment diagrams suggest you might be having sign convention issues, and the internal moment should be ## M(x) = M_A - F_x x ##
##M_B## is negative according to convention, so it has to cross the axis.
I am not really sure, so if i cut the beam at points ##a## and ##b## ,both ##F_x## and ##F_y## will create a bending stress and ##F_y## also a normal stress? Would this be the way to solve it, cutting 2 times once at ##a## , ##b##, and once at ##c##,##d##
  • · Replies 30 ·
