Communicating vessels(experiement)
  • Context: High School
  • Thread starter Thread starter Hepic
The discussion centers on the principles of hydrostatic pressure as it relates to two communicating vessels connected by a tube. When one bottle is raised, the hydrostatic pressure in the tube changes, causing water to flow from the higher bottle to the lower one due to the difference in pressure. The atmospheric pressure difference is negligible in this scenario, and the key factor is the hydrostatic pressure created by the height of the water column in the tube. Understanding these principles is essential for accurately predicting fluid behavior in connected systems.
  • Understanding of hydrostatic pressure principles
  • Familiarity with fluid dynamics concepts
  • Knowledge of communicating vessels and their behavior
  • Basic physics of pressure differences in fluids
  • Study the principles of hydrostatic pressure in detail
  • Learn about fluid dynamics and Bernoulli's principle
  • Explore experiments with communicating vessels to visualize fluid behavior
  • Investigate the effects of atmospheric pressure on fluid systems
Students of physics, educators teaching fluid dynamics, engineers working with hydraulic systems, and anyone interested in the behavior of fluids in connected containers.
Hepic
Lets say we have two bottles that communicate via a tube.
Level of water,will try to be the same at both bottles because If hydrosatic pressure is bigger at the one,will try after some seconds to become the same.(pushing down the water of bottle with the more watter).
So let's say that level of water is the same at both bottles.
Now,for example we take the first bottle and put that in bigger height(30 cm heigher than other bottle). We see that water from heigher bottle goes to bottle with less height. Hydrostatic pressure there is not because water were in the same level,but maybe now atomospheric pressure is active. Is correct that the heigher bottle has bigger atmospheric pressure,so it sends its water in the other bottle??
Sorry for my english. Thank you!
You are mistaken in saying "Hydrostatic pressure there is not because water were in the same level". You have to count the water in the tube connecting the two bottles.
(Strictly speaking the atmospheric pressure on higher bottle will be less than on the lower because there is less atmosphere above it- but with a difference of only 30 cm, that will be unnoticable.)
So,the heigher bottle has bigger hydrostatic pressure?
No. As HallsOfIvy said, you have to consider the water in the tube connecting the two bottles. What happens to he hydrostatic pressure at each point in the tube as you raise the first vessel by 30 cm?
So,If it this phenomeno is only about with tube,I can change waters via tube only(having the bottles at the same height?)?
That what I mean is,to leave the bottles in the same height,but to change the tube,and make it as it will be when I have one of bottles heigher. If I do that,water level will change??
Hepic said:
S
No, that won't work either. Here's something that might help you visualize what's going: Imagine that there is a plug in the tube, so that water cannot flow between the two vessels to equalize the level. Now calculate the hydrostatic pressures on either side of the plug - if they're equal nothing will happen when the plug is removed and if they're not equal water will flow from the high pressure side to the low pressure side and the water levels will change. Try this for each of the cases that you've asked about so far in this thread.
My english is bad,so I undestood what you mean but not at all.
Can you explain me with physics rules,why when I put a bottle heigher his water goes to the less heigh bottle?
(The heigher has more hydrostatic pressure?)
See diagram.
The pressure at A and B are different (not the same).
Yea,I understood that. The heigher will have more pressure because there is more water,but when we use bottles with cube and go higher the one bottle,water will be the same,will not be more?
When you raise the left-hand container, you are not raising the part of the tube that is connected to the right-hand container. Therefore, the water in that part is deeper after you've raised the container, so the hydrostatic pressure in that part of the tube is greater.
Hepic said:
. when we use bottles with cube and go higher the one bottle,water will be the same,will not be more?
Sorry. I do not understand what you say. Can you make a drawing.
http://postimg.org/image/512frpz47/
Here is a photo. In number 1 I show the first situation,and in number 2 the second situation.
When you go from 1 to 2,you raise the bottle with the water,so the water is not deeper,but has more pressure??
...has more pressure
Where does it have more pressure?
Please mark on the drawing where you are talking about. Bottom of the water?
The pipes are in the air above the water ??
I do not know what pressure there is. Can you explain me in what is the difference between 1 and 2,so water way changes?
Sorry we are still having problems communicating.
I don't understand your drawing. In 1 the pipe is not in the water. The end of the pipe is in the air. No water will flow.
In 2...
No water will flow. On the right... the pressure at the bottom of the pipe is higher. It is not high enough to raise the water above the surface.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 46 ·
