Commutation of differential operators
The discussion focuses on evaluating the commutator of the differential operator and the variable x, specifically \[\frac{d}{dx}\] and x. The initial calculation leads to the conclusion that the commutator \([\frac{d}{dx}, x]\) is the identity operator. Participants suggest using a test function to verify the results and explore properties of commutators to simplify the process. The final result confirms that \([\frac{d}{dx}, x] = 1\), demonstrating the relationship between differentiation and multiplication by x. Overall, the thread emphasizes understanding commutators in the context of differential operators.
magicfountain
Evaluate the commutator \left[\frac{d}{dx},x\right]
\left[A,B\right]=AB-BA
\left[\frac{d}{dx},x\right]=1-x\frac{d}{dx}
I don't know how to figure out x\frac{d}{dx}.
Try using a test function here i.e. calculate [d/dx,x]f(x) and when you are done make sure you get some expression (...)f(x) again then what is between the brackets is your commutator.
I actually just figured this out.
Can somebody please just check this one I did for mistakes?
[A,B]=[(d/dx + x),(d/dx - x)]
(AB-BA)f=(d/dx + x)(d/dx - x) f -(d/dx - x)(d/dx + x) f
(d/dx + x)(df/dx - xf)- (d/dx - x)(df/dx + xf)
(df^2/dx^2 - f - x df/dx)+(x df/dx - x^2f)-(df^2/dx^2 + f +x df/dx)+(x df/dx + x^2f)
=-2f
--> [(d/dx + x),(d/dx - x)]=-2
If f is any function then (d/dx)(x f)=x df/dx+ f while x(d/dx)f= xdf/dx. The difference is f so the commutator, [d/dx, x] is the identity operator.
=-2f
That's fine.
You could have also used a few properties of commutators to save yourself some work, namely [A+B,C]=[A,C]+[B,C] and [A,B]=-[B,A]. Using those, you should be able to show that [(d/dx + x), (d/dx - x)] = 2[x, d/dx], and you've probably already worked out that last one and found it to be equal to -1.
vela said:
That's fine.
Very helpful. Thanks!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 26 ·
