Compare centripetal acceleration of Mars and Earth
The discussion centers around comparing the centripetal acceleration of Mars and Earth in their orbits around the Sun. The original poster seeks to understand whether Mars has a larger or smaller centripetal acceleration compared to Earth, considering the implications of distance from the Sun.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between distance from the Sun and centripetal acceleration, questioning how velocity factors into the comparison. There is a discussion on applying Newton's law of universal gravitation to derive expressions for centripetal acceleration for both planets.
Some participants have provided guidance on using gravitational force to derive centripetal acceleration expressions. There is an ongoing exploration of the implications of the radius of the orbits on the accelerations, with differing interpretations emerging regarding the relationship between radius and acceleration.
Participants note that the question is conceptual and should not require specific data or variables, which influences the nature of the discussion. There is also a mention of potential misunderstandings regarding the relationship between radius and acceleration.
shnigglefratz
Is the centripetal acceleration of Mars in its orbit around the Sun larger or smaller than the centripetal acceleration of the Earth?
I assume that the relevant equation is a=v[itex]^{2}[/itex]/r since you are trying to compare the centripetal accelerations of Mars and Earth, however it is supposed to be a concept question according to the book so no data or variables should be needed to answer the question.
So i know that Mars is farther away from the Sun than the Earth is, so r is obviously greater for Mars. Therefore the perimeter of Mars' orbit around the sun is greater than the perimeter of the Earth's orbit around the Sun. What I am confused about is how to figure out the velocity of Mars, or Earth for that matter. Is the velocity not needed to answer the question and I am merely missing something, or can you just assume that because Mars is farther away from the Sun it has a greater centripetal acceleration based on a trend?
If I did anything against the forum rules/policies please forgive me as this is my first post on Physics Forums.
Considering the Earth only. The gravitational force between the sun and the Earth provides the centripetal force for the Earth. Can you find an expression for this acceleration?
(Hint: What does the law of universal gravitation say?)
So with Newton's law of universal gravitation it's: F = [itex]\frac{G(m_{Earth})(m_{Sun})}{r^{2}}[/itex]?
Right, so the centripetal acceleration of the Earth is therefore? (Newton's second law)
Do the same with Mars now.
so: m[itex]_{earth}[/itex]a = [itex]\frac{G*m_{Earth}*m_{Sun}}{r^2}[/itex]
divide by m[itex]_{Earth}[/itex]: a = [itex]\frac{G*m_{Sun}}{r_{Earth's Orbit}^2}[/itex]
Therefore for Mars the equation will be: a = [itex]\frac{G*m_{Sun}}{r_{Mars' Orbit}^2}[/itex]
Right, so you can see that if you take aearth/amars then GMsun will cancel out.
So the only factor that matters when comparing the two centripetal accelerations is the radius of their orbits. Therefore Mars has a larger centripetal acceleration because its radius is larger. Is that right?
That should be correct.
Thanks, I really appreciate all of the help :smile:. I just thought that the solution would involve more than one variable.
wrong if radius is larger acceleration is less
Wrong about what?
  • · Replies 83 ·
  • · Replies 32 ·
