Completely portable LaTeX system? Anything?
  • Context: LaTeX
  • Thread starter Thread starter symbolipoint
    Latex System
The discussion centers on the use of portable MiKTeX, which includes TeXworks, and the search for a compatible portable editor. Users recommend trying portable Emacs as a potential solution. The installation process for portable MiKTeX is straightforward, requiring no configuration of PATH variables. For mathematical typesetting, users are directed to online resources, including ShareLaTeX for guidance on LaTeX commands.
  • Understanding of LaTeX typesetting
  • Familiarity with portable software concepts
  • Basic knowledge of text editors, specifically Emacs
  • Experience with extracting and running executable files from USB drives
  • Explore the features of portable Emacs for LaTeX editing
  • Learn about mathematical typesetting in LaTeX using ShareLaTeX resources
  • Read "The Not So Short Introduction to LaTeX" for comprehensive LaTeX learning
  • Experiment with compiling LaTeX documents using TeXworks in the portable MiKTeX environment
This discussion is beneficial for students, researchers, and professionals who require a portable LaTeX solution for document preparation, particularly those interested in mathematical typesetting and using MiKTeX and Emacs.
symbolipoint
Education Advisor
There is a portable form of MiKTeX, but I have not yet found description of any portable editor program which could go along with it. Anyone knows of such a portable editor for use with portable MikTeX, please tell.
DrClaude said:
You could have a look at portable Emacs.
I checked those websites. I really did not understand the information there. A careful look into portable MiKTeX seems good right now.
Those other websites did not make clear what EMACS is. Not much documentation telling about how portable is it neither. Windows? Portable? Zipped portable but need to install? I'm confused.
JorisL said:
Portable miktex has TeXworks included see "how to use the portable edition" on http://miktex.org/portable
That seems like the neat way to go. The page did not say anything about configuring or setting path or what other settings to make to ensure the editor and the MikTeX will work and will work together. Does the portable form of these programs still need setting various PATHs and other settings?
Not certain, I have used it before but that's a long time ago.
I don't remember any problems with standard LaTeX-editing.
I advise you just set it up and try some stuff (follow the steps I referred to before). Perhaps even try to compile some old tex-files you have in the portable environment.
That way you know exactly what's possible and what not.
trying >> thinking in this case :-)
The instructions on the web page did not say anything about configuring or setting options or paths, so I will just extract the EXE 7zip file to a usb flashdrive and see what happens. I have not any TEX files. I had used TeXaide a few times, but I never was too strong at knowing the typesetting codes; that program was graphical with formatting buttons, and I would copy & paste. TeXaide worked well on the physicsforums, and also in Jarte wordprocessor.
The unpacking time is taking between 40 and 50 minutes,
... DONE now, took 40 minutes to unpack.I ran miktex-portable.cmd as administrator, then rightclicked to see the taskbar menu. Not sure what next to expect. Options maybe for any configuring? I'm no longer clear on this. TeXWorks and MikTex are supposed to be portable as unpacked from the 7zip file, so guessing no path variable or other configuring should be needed...?
Nobody answered the last post yet but found it that the package as portable has a helpfile included, with some introductory guidance. TeXworks can be opened, a simple document created, saved, and the compile button digests the .TEX found in the editor window and forms a PDF display according to the code in LaTeX. No configuring, no setting a PATH variable, no other options or settings need be made.
So far, no guidance found in the helpfile for Mathematical typesetting, but a brief online search turned-up this useful site: https://www.sharelatex.com/learn/Mathematical_expressions
Some different code or commands shown there.
I have not yet taken the chance to try any of this for mathematics symbols.
Emacs is a text editor, and is very well adapted for programming and LaTeX, among many others. I don't have Windows, so I can't very this, but the information here states that you can have it as an executable on a USB stick, no installation needed.
Do you mean that you want to learn LaTeX? If so check out The Not So Short Introduction to LaTeX.
12K
