Complex analysis of electrostatic problem
Morto
I'm not sure whether to post this in the Mathematics or Physics forums, but I figure this problem is easily reduced to its transformation irrespective of the physics it describes.
Consider a semi-infinite sheet of (infinitely thin) conductor charged to a potential [tex]V[/tex]. It is placed at a distance [tex]h[/tex] perpendicular to a perfectly screening bulk conductor (so the electric field is always perpendicular to the surface). See the attachment below. I want to investigate the charge density on the surface of both sheets. I'm struggling to determine the transformation that can describe the electrostatic field.
Diagram of a semi-infinite conducting sheet at potential phi=V lying along the x-axis, a distance h from an infinite plane conductor at phi=0 on the y-axis, with horizontal arrows showing the electric field E pointing rightward.
Now, I have calculated a similar problem with a semi-infinite conducting plane paralell to an infinite conducting plane at a distance [tex]h[/tex]
Diagram of a vertical infinite line on the y-axis, with a horizontal semi-infinite line labelled phi=V extending right from it, above an infinite horizontal conducting plane labelled phi=0 on the x-axis.
I have transformed it into the upper half-plane (so it looks like a capacitor), and I found the transformation
[tex] z = h \left( \frac{w}{V} - \frac{1}{\pi} \left(1+ e^{-\frac{\pi w}{V}} \right) \right)[/tex]
determines this electrostatic field. How can I transform my problem with perpendicular planes into something similar? Can I use this result, with another transformation? Any help would be greatly appreciated.
You should have posted this in the Physics boards, because not all the Math students are familiar with electrostatic concepts (sigh).
