Complex Analysis Singularities and Poles
The discussion centers on the analysis of singularities and poles in complex functions, specifically focusing on an analytic function f with a zero of order 42 at z=0. It is established that f' has a zero of order 41 at z=0, indicating that the derivative loses one order of the zero. The function 1/f exhibits a pole of order 42 at z=0, as the reciprocal of a function with a zero results in a pole of the same order. Lastly, f'/f has a pole of order 1 at z=0, as the derivative introduces an additional factor of z in the denominator.
  • Understanding of analytic functions and their properties
  • Knowledge of zeros and poles in complex analysis
  • Familiarity with the concept of holomorphic functions
  • Basic differentiation techniques in complex calculus
  • Study the definitions and properties of analytic functions in complex analysis
  • Learn about the relationship between zeros and poles in complex functions
  • Explore the concept of holomorphic functions and their representations
  • Investigate the implications of the quotient of analytic functions on singularities
Mathematicians, students of complex analysis, and anyone interested in understanding the behavior of analytic functions and their singularities.
bballife1508
Assume throughout that f is analytic, with a zero of order 42 at z=0.
(a)What kind of zero does f' have at z=0? Why?
(b)What kind of singularity does 1/f have at z=0? Why?
(c)What kind of singularity does f'/f have at z=0? Why?
for (a) I'm pretty sure it is a zero of order 41
for (b) I'm almost sure it is a pole of order 42
but for (c) I am not quite sure nor can I really explain any of a-c
PLEASE HELP
Since you arrived at a plausible answer, you must have some intuition for this. Explain it, and go back to the definitions if you need to. You must have some idea about the form of a holomorphic function with a zero of order 42.
are my answers correct and how can i do (c)?
Okay, if some analytic function f has a zero of order n at z = a, then you can certainly write it as f(z) = (z-a)^n * h(z) where h is holomorphic, right? This much should at least be true even if all you had was a sensible notion of a zero of a function. So go from here to explain a)-c). It is NOT hard to work out the details.
is it sufficient to say that
f(z)=z^42*h(z) which implies that f'(z)=42z^41*g(z)
so f'/f has an extra z on the bottom so there is a pole of order 1?
Looks good, though you don't really need the g.
what do you mean i don't need the g? i can't use h still correct?
