Complex orthogonality of electric and magnetic fields
The discussion centers on the orthogonality of electric and magnetic fields when expressed in complex form, exploring the implications for their mathematical treatment in electromagnetism. Participants examine the validity of cross and dot product relations in this context, as well as the conditions under which these relations hold.
  • One participant expresses difficulty in understanding the orthogonality of electric and magnetic fields in complex form, noting that the definition of orthogonality for complex vectors differs from that of real vectors.
  • Another participant suggests that complex vectors in electromagnetism can be expressed as a product of a complex scalar and a real vector, allowing for a reduction to real dot and cross products.
  • Some participants assert that orthogonality holds, stating that the dot operation occurs on real basis vectors while complex coefficients do not affect this property.
  • Concerns are raised about the validity of orthogonality when calculating quantities beyond linear operations, such as energy density and the Poynting vector, which require taking the real parts of the fields first.
  • There is a discussion regarding the implications of complex wave vectors, with questions about whether the dot product relation holds in such cases.
  • One participant clarifies that complex wave numbers can appear in solutions to Maxwell's equations, indicating that the imaginary part represents wave damping.
  • Another participant notes that the Poynting vector remains in the complex domain, with its real part representing energy flow and the imaginary part representing reactive power.
Participants express differing views on the implications of using complex representations for electric and magnetic fields, particularly regarding the conditions under which orthogonality holds. The discussion remains unresolved, with multiple competing perspectives on the treatment of complex fields.
Limitations include the dependence on the definitions of orthogonality in complex versus real vector spaces and the conditions under which various mathematical operations are valid. The discussion highlights the need for careful consideration when transitioning between complex and real representations in electromagnetism.
aravantv
Hi,
I have a hard time finding a justification that electric and magnetic fields are still orthogonal when presented in complex form. As far as I know the notion of orthogonality for complex vectors is not as intuitive as the one for real vectors. Notably, [itex]\vec{x}\cdot\vec{y}=0[/itex] does not imply that [itex]\Re(\vec{x})\cdot\Re(\vec{y})=0[/itex] (the former dot product is a complex one, the latter is a real one).
Similarly, does the cross product relation between the electric field, the magnetic field, and the wave vector still hold?
Cheers,
V.
PS: I'm a novice in electromagnetism and a novice on this forum, please tell me if I did not respect any rule that I would be unaware of.
Am I right by observing that all complex vectors that we meet in electromagnetism can be written as [itex]z\vec{x}[/itex] where [itex]z\in ℂ[/itex] but [itex]\vec{x}\in ℝ^{n}[/itex]?
In this case the complex cross and dot products can be easily reduced to their real counterparts:
[itex]z_1\vec{x_1}\odot z_2\vec{x_2}=(z_1z_2)(\vec{x_1}\cdot\vec{x_2})[/itex]
and
[itex]z_1\vec{x_1}\otimes z_2\vec{x_2}=(z_1z_2)(\vec{x_1}\times\vec{x_2})[/itex]
where [itex]\cdot[/itex] and [itex]\times[/itex] (resp. [itex]\odot[/itex] and [itex]\otimes[/itex]) are the real (resp. complex) dot and cross products.
At least this somewhat allows to retrieve the geometrical interpretation... ?
V.
The orthogonality holds. The dot operation takes place on the real basis vectors. The complex coefficients just go along for the ride.
This problem occurs usually when treating electromagnetic waves in terms of plane-wave modes. Then it is in most cases easier to simply write
[tex]\vec{E}=\vec{E}_0 \exp[-\mathrm{i} (\omega_{\vec{k}} t-\vec{k} \cdot \vec{x})][/tex]
with [itex]\vec{E}_0 \in \mathbb{C}^3[/itex], [itex]\omega_{\vec{k}}=c |\vec{k}|[/itex], instead of taking the real part, which is of course the physical field meant to be described here. An analogous formula also holds for the magnetic components of the field or for the four-potential of the field.
Of course, this works only as long as you perform only linear operations like the standard differentialoperators, div and curl, or look at superpositions of fields, or cross and dot products with real vectors (like [itex]\vec{k} \cdot \vec{E}=0[/itex] for a free field in the vacuum).
As soon as you calculate something beyond linear operations or multiplications with real scalars or vectors like the energy density [itex]\mathcal{E}=(\vec{E}^2+\vec{B}^2)/[/itex] (in the vacuum with Heaviside-Lorentz units) or the Poynting vector [itex]\vec{S}=\vec{E} \times \vec{B}[/itex], you have to take the real parts of the fields first and do then the products.
Do you mean that we are indeed in the situation that I described in my second post?
vanhees71 said:
(...)As soon as you calculate something beyond linear operations or multiplications with real scalars or vectors like the energy density [itex]\mathcal{E}=(\vec{E}^2+\vec{B}^2)/[/itex] (in the vacuum with Heaviside-Lorentz units) or the Poynting vector [itex]\vec{S}=\vec{E} \times \vec{B}[/itex], you have to take the real parts of the fields first and do then the products.
So you mean that [itex]\vec E\cdot\vec B=0[/itex] holds only for the real parts of both vectors? It seems contradictory to what Antiphon just wrote, isn't it?
I think I've seen in some contexts some complex wavevectors [itex]\vec k[/itex]. Then, from what you say, it means that [itex]\vec{k} \cdot \vec{E}=0[/itex] does not hold in such a context?
No, that's not what I said. Complex wave numbers appear, e.g., in the solution of the Maxwell equations in wave guides. The imaginary part in the wave number describes just the damping of the wave.
But you wrote that the operation was valid only if one complex vector only was involved, right?
Ok, so what does this tell me about the dot product?
Actually the Poynting expression you have for S remains in the complex domain. The real part of S is energy that traverses the surface. The imaginary part of S represents reactive power (power which crosses back and forth across the surface on each cycle.)
  • · Replies 23 ·
